Old 05-29-2009, 04:51 PM   #1
LvnInPeace
LvnInPeace is on a distinguished road
1992 SC2
Default Misfire between 2 and 3k.....
I can't not seem to figure out what the problem is...It only does it between 2 and 3k rpms...it runs smooth below that and if it is missinb above that I can't hear it....Any ideas on where to start?? Start with plugs? The ECTS is the newer style as well.... was replaced about 3500 miles ago... Thanks guys
1992 SC2 5-Speed
2.25" cat back with 2.25" inlet to 4" outlet muffler
Teal W/ all black leather interior, Power Steering, Windows, Sunroof, Locks
LvnInPeace is offline   Reply With Quote
Old 05-29-2009, 05:49 PM   #2
Default Re: Misfire between 2 and 3k.....
A misfire in the upper 2K and low 3K range is usually the plugs and/or wires. What brand and number plugs are you using?
How old are the wires and how many times have they been disconnected from the plugs?
Old 05-29-2009, 06:10 PM   #3
LvnInPeace
1992 SC2
not really sure on the brand....the wires are brand new...pulled off maybe 5-6 times ish..... when I was trying to solve the starting issue I had... what brand should I get to try? the NGK Coppers? any specific part number or anything to ask for? I'll be going to O'Reily...
1992 SC2 5-Speed
Old 05-29-2009, 06:40 PM   #4
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
Bkr5esa-11
NGK
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Fox Slaughter is offline   Reply With Quote
Old 05-29-2009, 07:13 PM   #5
+1^^^And nothing else. You might have to do some shopping.
Old 05-29-2009, 07:39 PM   #6
93SC2'in
93SC2'in is on a distinguished road
93SC2'in's Avatar
1993 SC2
i had this problem and cleaning the back of the icm and spot on where it mounts to the transmission and some ngk's and it went away
93 SC2, 5-speed, <dead and gone>
95 SL2 5-speed, oem header, gsi TB, sprint 2.0, kyb gr2's, wb02, SAFCII, CAI, 17"s
Speed Kills - save lives, Drive a honda
93SC2'in is offline   Reply With Quote
Old 05-29-2009, 09:28 PM   #7
rc1488
Bad wire order. Its 4-1-2-3 at the coil towers. If you put the wires on in any other order including 1-4-2-3 or 4-1-3-2 you get a similar symptom. This is even more likely since you replaced the wires recently and perhaps put them back on in correctly. Cylinder 1 is the passenger side.
Old 05-30-2009, 02:57 PM   #8
LvnInPeace
1992 SC2
Found them online at Jegs.com for 2.69 each..good deal or should I continue to shop around?
1992 SC2 5-Speed
Old 05-30-2009, 05:34 PM   #9
Fox Slaughter
I think I pick mine up at like Murrays (now O'Reilys) for like 2.40 a pop or something. The only real way to mess up firing order is if you mess it up on the towers. Cause the wires are lengths, so you can't mess up that part.
Old 05-30-2009, 06:16 PM   #10
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
I picked up 4 NGK BKR5ES-11 spark plugs at Murray's today. Is there a difference between these and the BKR5ESA-11?
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
blackeagle1 is offline   Reply With Quote
Old 05-30-2009, 07:23 PM   #11
Yes. The "A" is a slightly extended nose, helps with idle RPM firing.
Old 06-03-2009, 10:00 AM   #12
gbruce
gbruce is on a distinguished road
Idea Re: Misfire between 2 and 3k.....
I've been chasing the same problem on my 1996 sl2. After reading all the posts i still couldn't fix it. My sensors were all working, firing order was correct. Plugs, wires, and coils were working, all sensor/wire connections were good. The one thing that solved it was a fuel pump. Check your fuel pump pressure, replace the fuel filter. On my car, the pressure was great at an idle, OK at a high idle, but dropped to nothing under a load. I don't know why, but two days ago, my car died and I had to replace the fuel pump. A tear came to my eye when i took the car for a ride down the road and the misfiring stopped, and I actually had power! Check the fuel system!!
by the way- Thank you Oldnuc for your continued help and guidance to all of us Saturn owners.
gbruce is offline   Reply With Quote
Old 06-03-2009, 10:12 AM   #13
Good tip! Usually a weak fuel pump also shows up as a slightly low Idle fuel pressure. Doing a pressure - flow test on the fuel pump is not a normal DFIY job as it requires a set of adapters and a means for measuring both pressure and flow at the same time. The pump should supply 45 - 55 gph @ 65psi, that is 96 - 117oz/min @ 65psi min.
misfire? nitroussaturn Vue Tech 19 04-24-2014 05:00 PM
misfire on #3 techsista S-Series Tech 2 06-14-2009 01:07 AM
Misfire gm767 S-Series Tech 1 04-22-2009 01:21 PM
Misfire Booncha57 S-Series Tech 31 03-25-2009 11:37 AM
Misfire 1993SC2 S-Series Tech 23 12-15-2003 10:44 AM
