Old 01-10-2009, 07:21 PM   #1
twhitney
twhitney will become famous soon enough
twhitney's Avatar
1994 SC2
Default Cylinder Head Gasket Replacement...
So tonight when I was checking some other things with my car... particularly the spark plugs because i do every so often to make sure they are burning well... and I noticed that the oil in my two middle cylinders was pretty bad... its been like that for some time now... and i've been planning on changing the Cylinder Head Gasket...
First off... the oil soaks the threads of the spark plugs, but does not get into the firing chamber or anywhere else, so its not causing any problems... but I want to take care of it before the leak gets any worse.
Only problem is i don't have a torque wrench... Ive been meaning to pick one up at Sears at somepoint soon... I'm guessing the torque on the head cover is pretty important isn't that right? The Haynes manual tells me what order to tighten them and what torque they should be... so I'm guessing I'm at bay until then.
Anybody else have problems with this or ever replace their cylinder cover gasket? Any stories or something useful that you might be able to share for when I do it?
___________________________
Tyler
1994 SC2 DOHC
2006 Mazda3 sGT
twhitney is offline   Reply With Quote
Old 01-10-2009, 08:08 PM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Cylinder Head Gasket Replacement...
You're talking about a cam cover or valve cover gasket, not a cylinder head gasket. The head gasket goes between the head and the block, the cam cover goes between the head and the ...well....the cam cover. Search the forum for replacing the cam cover gasket, it's been covered 958243857823475092 times already. You need the preformed gasket, if you go to a parts store and they hand you a tube of RTV, hand it back, and walk out.
Certified Saturn Technician
Old 01-10-2009, 09:30 PM   #3
The torque spec in some of the Hyanes manuals is WRONG. The correct value is 89in-lb. You need a torque wrench calibrated in inch-pounds, in-lb and have the 80s in the middle of its range.
Old 01-11-2009, 02:27 AM   #4
twhitney
twhitney's Avatar
1994 SC2
I'll just search the forum then... I figured its probably been covered... I should've searched before making the thread.
Just to clarify... I was told that the bolts holding the cam cover on need to be replaced when doing this... is this right?
... and also found it in a search of the forum
Note - these are torque-to-yield bolts and must be replaced with new ones if loosened/removed.
you're talking about a cam cover or valve cover gasket, not a cylinder head gasket. The head gasket goes between the head and the block, the cam cover goes between the head and the ...well....the cam cover. Search the forum for replacing the cam cover gasket, it's been covered 958243857823475092 times already. You need the preformed gasket, if you go to a parts store and they hand you a tube of RTV, hand it back, and walk out.
Thanks for clarifying Squareback... I never know what the name of it is.. I get confused as I'm not the best mechanic in the world in terms of what I know... I can do whatever job when told/shown what to do and given the proper tools... but my knowledge is slim with the innerworkings and names of some things.
As for the gasket itself... I found the preformed gasket on RockAuto.com ... that i know is what I need, I'm not a fan of the AdvancedAuto in my town, they give out wrong info all the time... AutoZone is pretty good, but they're not the best.
I'll probably end up doing this at my dad's garage where he has the proper torque wrench and other necessary tools / space.
Tyler
1994 SC2 DOHC
2006 Mazda3 sGT
Old 01-11-2009, 02:46 AM   #5
twhitney
twhitney's Avatar
1994 SC2
Also... just to confirm I do know what I am talking about and I'm not a total idiot...
Is this what i'm looking for? I have an aluminum cam cover on my DOHC.
Tyler
1994 SC2 DOHC
2006 Mazda3 sGT
Old 01-11-2009, 02:27 PM   #6
That looks like the part.
Old 01-11-2009, 02:30 PM   #7
Cheyne
Cheyne has a spectacular aura aboutCheyne has a spectacular aura about
2000 SL2
You can reuse the bolts or I should say that I have.
Old 01-11-2009, 02:48 PM   #8
Squareback
Squareback's Avatar
2005 ION-2 Sedan
No, that is not right. The cylinder head bolts are torque to yield and must be replaced, the cam cover bolts are not, and are infinitely reuseable. No need to replace anything but the gasket, and don't forget a dab at each corner where the timing cover meets the head.
Old 01-11-2009, 03:44 PM   #9
Growser
Growser is on a distinguished road
Growser's Avatar
When you tighten the bolts it'll feel like it's way too loose. Trust your torque wrench - these bolts are very easy to break off. Also do a search on the topic for the tightening sequence. There is a trick in getting a tight seal and it has to do with the order you tighten the bolts.
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Growser is offline   Reply With Quote
Old 01-11-2009, 05:49 PM   #10
twhitney
twhitney's Avatar
1994 SC2
Okie dokie, thanks for the help yet again. I didn't see why the cam cover bolts would be torque to yield... but I have no idea... and it seems like many people confuse cam cover gaskets and head gaskets when talking to me about the stuff which just confuses me further (with wrong names etc.)
Thanks a lot.
Thank you Growser... my Haynes manual shows the proper order to tighten... I know what you mean by things feeling too loose... I've been there, but i know better because a few more turns and they could go SNAP. hehe
Thanks for the heads up OldNuc, I very likely would've just followed the specifications in the manual.
Tyler
1994 SC2 DOHC
2006 Mazda3 sGT
Old 01-11-2009, 09:20 PM   #11
JerryHughes
JerryHughes's Avatar
1997 SL
You're lucky you found the gasket at Rock Auto. My 97SL doesn't have one listed----only RTV.
Jerry
1.9 SOHC Cylinder Head/Head Gasket..... Coolant Leak BRIAN41920 S-Series Tech 12 01-21-2014 03:40 PM
cylinder head gasket replacement peter strawn L-Series Tech 15 02-27-2009 11:45 PM
Questions on Cylinder Head Gasket Job xserver S-Series Tech 13 09-04-2008 07:52 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 03:42 AM
Blown head gasket...vs....cracked cylinder head?? schultp S-Series Tech 1 06-25-2007 11:16 PM
