Old 09-24-2023, 11:49 AM   #1
iceman2020
iceman2020 is on a distinguished road
Wrench Shifter will not move, car will not start
I have a 2006 Saturn View
For the last few weeks about one third of the time
I try to start the car, it will not start. And with the key in
the shifter will not move from park. So far I have tried
moving things a bit and always after a few minutes the
shifter will move into neutral and it will start. Do you
know what is causing this and how to fix the problem?
Also, how urgent is the issue? I do not want to find myself
in a situation where it will not start and I have to be towed
Thank you for any help
iceman2020 is offline   Reply With Quote
Old 09-30-2023, 09:37 AM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Shifter will not move, car will not start
...It's possible the shifter cable is getting seized. and not allowing the shifter to move properly. That would also not let it start if it is not in park all the way. I would say try a new cable ,hope that helps, just my .02, DC
Old 10-08-2023, 09:44 AM   #3
ArtVandelay
ArtVandelay is on a distinguished road
2009 VUE 2.4L
Sounds like you are having a problem with the Passlock security system. You should be seeing a warning light (looks like a car with a padlock next to it). If you aren't seeing it - maybe the warning light is burned out?
The first thing you might try is getting a new key made. I had a 2004 Vue for 12 years / 140,000 miles . The only problem I had with it was binding ignition lock cylinder (key would get where it was hard to turn). To fix it I had to have a new set of keys roughly every 30,000 miles until at 100,000 miles I replaced the whole cylinder/lock assembly. Worked great for the rest of the time I had that Vue.
There's a ton of posts on this forum about Passlock - how it works, problems, how to bypass, etc.
ArtVandelay is offline   Reply With Quote
Old 10-08-2023, 03:25 PM   #4
2NDSOUT
2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light
2NDSOUT's Avatar
1994 SL2
1999 SL
Aside from doing some research on the Passlock system- I would also throw this out there:
You mentioned in your post- that putting your Vue into Neutral will get the vehicle to start.
Granted- most of my wrenching experience was on my S-Series cars; I will throw this out there:
When I owned my 94 SC1- I had an issue sometimes with the car starting- and eventually came to discover that my Neutral Safety Switch was bad. I could only start the car, with it in Neutral. Once I got the switch replaced, the car ran normally and started normally again.
I would check the Neutral Safety Switch on your Vue, and see if that- possibly in conjunction with your Passlock system- maybe these combined, are giving you issues.
Just my thoughts.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
2006 saturn vue shifter
2008 Aura Shifter Won't move from park but the car rolls jwoodyu Aura General 7 04-29-2016 05:07 PM
'99 SL2 5spd hard move shifter saleenman S-Series Tech 2 05-24-2014 02:25 AM
Clutch stuck in my 99 Saturn SL2? Pedal still can move, but car won't start in 1st? SeanMaster364 S-Series Tech 19 05-04-2012 12:37 AM
Shifter wont move jimyoung28 S-Series Tech 8 05-29-2008 06:17 PM
Consensus??: Start with MMO, move to TEC if needed? TedL S-Series Tech 7 11-09-2003 12:16 AM
