Old 09-28-2013, 11:03 AM   #1
willm
willm is on a distinguished road
Default 1999 Sl 1.9 lt multi misfire
I had code po400 and checked and cleaned EGR vlv, EGR vlv was replaced before I bought this 6 months ago, has always had high idle 11-1200 rpm. Cleared code but would come back in a few days. All of a sudden started bucking and jerking, now code po300. Removed throttle body and cleaned and replaced IAS, runs ok high on idle cold still, once warmed up bucking and jerking,po300 come up. Has new NGK plugs and napa wires. Any help would be awsome.
willm is offline   Reply With Quote
Old 09-28-2013, 11:49 AM   #2
Banjoman
Banjoman is on a distinguished road
Default Re: 1999 Sl 1.9 lt multi misfire
Look around with the search feature for P0300 issues, there's a lot to find.
A bad coil, or maybe just cleaning the coil terminals and grounds. It may also be a vacuum leak with the high idle. If the coil terminals have corrosion on them, use a green scratch pad and clean them off.
Banjoman is offline   Reply With Quote
1999 1.9 multi missfires
1999 SL1 misfire SLOturtle S-Series Tech 8 12-02-2015 06:19 PM
H/L multi switch rowdydog S-Series Tech 1 01-20-2013 07:28 PM
Multi Queston Thread. EvilSL2 Mods and Performance 17 03-15-2003 12:22 AM
multi point nitrous toeachitsown Mods and Performance 15 06-17-2002 01:04 PM
