Old 08-08-2004, 06:41 PM   #1
saturndog
saturndog is on a distinguished road
Default 1998 saturn sl coolant leak
coolant appears to be leaking from the firewall where the two rubber hoses for the ac? or heater core overflow is. strange enough it is emitting from the two hoses on the firewall. i have replaced the radiator, water temp sensor, ect and noticed that the coolant is dripping from the two tubes on the firewall. any ideas. is the core bad or is there a valve or what that needs to be relplaced? thanks...
saturndog is offline
Old 08-08-2004, 09:49 PM   #2
Default
Rare to see bad hater cores on Saturns. Have you made sure that it is coolant for sure and if so not running down the hoses from higher up? No valving in the heater core system so if it is leaking from the heater core it needs to be replaced.
ssicarman is offline
Old 08-09-2004, 07:40 PM   #3
saturndog
Default
the coolant appears to be emitting from the two rubber tubes in the firewall. are these tubes the ones that release moisture from the ac system as it cools? again does this have anything to do with the engine coolant/cooling system? confused? thanks again with where to begin to correct this problem. i don't want to go to the dealership. anyway thanks again.
Old 08-09-2004, 08:37 PM   #4
Default
Define "rubber tubes"?
Not hoses leading to the engine or anywhere else? Just kind of hanging out and down from the firewall? If so then they are either cowl drains or the drain (s) for the HVAC box in the car. Are you sure it is anti freeze coming out? Not just water.
Old 08-09-2004, 08:59 PM   #5
wrg813
wrg813 is on a distinguished road
Default
From where you are looking, you may want to consider the intake manifold slightly leaking. Shift your view and tell us what you see.
wrg813 is offline
Old 08-09-2004, 09:06 PM   #6
saturndog
Default
the tubes are located in the middle lower section of the firewall above the axle. they leak water/coolant when the car is parked not running. maybe i am wrong but it appears to be a direct correlation to the amount of liquid is leaked to the level of the coolant bottle. i just checked the oil which i changed about 4 days ago and it is as clear as can be. not leaking into the oil but again it appears as a drip drip drip from those tubes? the tubes are below the hoses that enter into the firewall for the heater core and they do not appear to be leaking. ok am i off base how to check?
Old 08-09-2004, 09:09 PM   #7
saturndog
Default
i have layed beneath the car watched it drip from the indicated tubes, chinese water torture style, onto my head. the leak is not comming from the engine, manifold ect.
1998 sc2 leak pumba1239 S-Series Tech 17 03-01-2009 01:29 PM
tips on fixing a sl2 2000 saturn, with a coolant leak, near the right front tire grinthenbearit S-Series Tech 9 10-07-2008 06:22 AM
Typical Location of 1998 SW2 Radiator Leak? bumpdraft S-Series General 20 01-14-2008 07:12 PM
coolant leak saturn LS1 marshman L-Series Tech 6 03-13-2007 08:26 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 12:56 PM
