Old 02-15-2008, 08:15 PM   #1
photoworks
photoworks is on a distinguished road
1994 SL1
Default Won't idle when cold; hard starting when very cold
First: great forum - great cars. My 94 SL1 has been trouble free since I got it in 2003. Issue: Won't idle when cold; hard starting when very cold. Took it to my trusty shop and they say: replace coolant temp sensor & sensor in coolant overflow jug. $500. Does this sound reasonable? I have skills. How tough? Should I check with a dealer shop?
Thanks for any help.
photoworks is offline   Reply With Quote
Old 02-15-2008, 10:10 PM   #2
richpin06
richpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nicerichpin06 is just really nice
richpin06's Avatar
Default Re: Won't idle when cold; hard starting when very cold
Originally Posted by photoworks View Post
How tough?
Welcome:Not tough at all.If you have a 13mm deep socket and ratchet your in business.With a cold engine remove the expansion tank cap(were you fill the coolant)and reinstall.Remove the wire connector(the one with two wires)from the sensor by squeezing and pulling.Check the connector for corrosion,if any is found replace connector.Remove sensor(a small amount of coolant will be lost) and install new sensor. (PCM sensor)
Old 02-17-2008, 04:23 AM   #3
virnin
virnin is on a distinguished road
virnin's Avatar
That should have ZERO effect on the performance of the engine unless it has failed completely and you run out of coolant. The only thing that sensor does is turn on a "Low Coolant" light in the instrument cluster. If that light isn't on and your coolant is not low then I can't imagine why they would recommend replacement.
virnin is offline   Reply With Quote
Old 02-17-2008, 03:24 PM   #4
mac99sl2
mac99sl2 is on a distinguished road
mac99sl2's Avatar
1998 SL
Im sure the shop meant the ECTS (PCM sensor) Why would they change the temp sending sensor for drivability issues? N E ways. You can change your own ECTS (PCM) sensor for a fraction of the cost like my buddy rich says. I got my ECTS for 12 buck @ auto-stoned. Get a 13 mm deep socket and change the S.O.B. if that doesnt fix your issue then give it to the shop to rip you off. click this link to find easy instructions on how to change it.
http://www.saturnfans.com/forums/showthread.php?t=37884
Do or do not, there is no try. -Yoda
mac99sl2 is offline   Reply With Quote
Old 02-17-2008, 09:05 PM   #5
hit_n_run
hit_n_run is on a distinguished road
replace ... sensor in coolant overflow jug.
That sensor is not replaceable. You'd have to drain all the coolant and replace the overflow jug altogether.
Besides, that sensor won't go bad unless it's constantly hitting air (which means constant low antifreeze. Then, it corrodes.
Replace that ECTS and you're more than likely good to go.
hit_n_run is offline   Reply With Quote
Old 02-18-2008, 01:24 PM   #6
photoworks
1994 SL1
Thumbs Up Re: Won't idle when cold; hard starting when very cold
Thanks to all for great help. And patience. Especially since I've discovered this ECTS issue has been discussed for years.
Richpin and mac: it was the easiest car repair I've ever done. Connector was immaculate and the part was $9. Autozone had no sealant on it, so I used teflon tape. It runs like a top! Still has crank windows and an 85 hp engine, tho. I still got more than I paid for.
virnin: Point taken. Didn't make sense to me either.
hit n run: Absolutely correct. In the shop's defense, I've used them for years and they've always made sense before. Replacing the jug is what I should have said.
BUT, they charged me $80 for the diagnosis.
Thanks for the new car!
Good cold start, trouble starting when not cold, fast idle 2001 SL2 composerchris Community Center 2 12-05-2008 03:02 AM
04 3.5l hard to start in cold (45 degree cold) SaturngirlSc2 Vue Tech 8 04-02-2008 07:08 PM
hard clutch, very cold out SiLenZe Vue Tech 5 03-02-2008 10:12 AM
Hard cold starting justgiver S-Series Tech 7 02-05-2007 11:03 PM
