Old 09-24-2022, 09:39 AM   #1
Tbyrne
Tbyrne is on a distinguished road
2004 VUE 3.6L
Question 2004 Vue Center console removal to access E-Brake
I googled like crazy the last two days and found zero videos or chats on the removal of the center floor console to get to the E-Brake shifter assembly. I have zero resistance when pulling up the handle. Both rear tires have the cables attached. So I need to see if the attachment at the handle is loose or broken, won't pass NYS inspection without the E-Brake working.
I see 4 screws around the top portion on the console but do not see anything for bottom portion.
Any videos or guides on how to do this for the 2004 Vue?
Tbyrne is offline   Reply With Quote
Old 09-24-2022, 10:25 PM   #2
Mr Toad
Mr Toad has a spectacular aura aboutMr Toad has a spectacular aura aboutMr Toad has a spectacular aura about
Mr Toad's Avatar
Default Re: 2004 Vue Center console removal to access E-Brake
1. Position the front seats rearward.
2. Reach under the front seats to access the lower console screws.
3. Remove the console screws.
4. Remove the cup holder liner.
5. Remove the cup holder screw.
6. Lift the rear of the center floor console.
7. Disconnect the electrical connector to the auxiliary power outlet.
8. Remove the console from the vehicle.
2005 Saturn Vue
Front Wheel Drive
3.5L V6 Engine
5AT Automatic Transmission
180,000+ miles
Mr Toad is offline   Reply With Quote
Old 09-25-2022, 12:01 PM   #3
Tbyrne
2004 VUE 3.6L
Wrench Re: 2004 Vue Center console removal to access E-Brake
I solved my problem. I first unscrewed the storage bin and disconnected the power connector. This technically was a waste of time as I forgot about the pull out cup holder which blocks my view of anything below it. I found the 4 bolts along the bottom edge and removed them. 2 had rounded off heads so I didn't reinstall them, I'll get new as they are the front ones that I have to go under the seats. Yes removing the front seats would have made it easier to work on, it was just another headache I didn't want to deal with.
Once the floor console was removed, I found the clip came off the cables. Reinstalled and tested and the brakes hold so I'm good to go to get my inspection done.
Old 09-25-2022, 12:05 PM   #4
Tbyrne
2004 VUE 3.6L
Originally Posted by Mr Toad View Post
1. Position the front seats rearward....
Thanks, I discovered the 4 bolts after I posted the question.thanks for replying, I appreciate it.
Center console removal JTC 2008 Vue 0 07-10-2014 10:19 AM
Center Console Removal 2Fast4U Vue General 3 11-26-2006 09:57 AM
ls1 center console removal Timma L-Series General 6 04-20-2005 11:32 AM
Center Dash Console Removal and AUX channel access DJPSC Vue General 4 04-12-2005 07:14 PM
Center console removal Tim T S-Series General 1 05-05-2004 09:26 PM
