Old 03-12-2006, 12:19 AM   #1
smokyvue
smokyvue is on a distinguished road
Default Roof Rack Bars Installation 05 VUE
Anyone had any experience good or bad installing roof rack bars? I believe they're installed with Torx srews and locktite.What;s the secret to removing and reinstalling the screws without strippng them or damaging plastic?
smokyvue is offline   Reply With Quote
Old 03-13-2006, 01:15 AM   #2
burlyvue2
burlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura about
2004 VUE 3.5L
2000 L-Series 3.0L Wagon
Thumbs Up Re: Roof Rack Bars Installation 05 VUE
Hello smokeyvue,
This is a well discussed topic on the site. Do a search. There are many hits.
http://members.cox.net/a1l3n/vue/22731383.pdf
This is a how to. Very usefull.
My experience is to use a power tool with the EXACT fitting torx bit. Use a step ladder to get over the vehicle and put your weight on the tool to crack the screw loose. I got all mine out no problem using this method. Others on the site manged to break screws and strip the heads. The main problem is GM installs these torx screws with BLUE LOCTITE. Very strong stuff. The install kit calls for RED LOCTITE for re-installation.
After I had my bars installed and all good I applied a black caulk (DAP ALEX PLUS Acrylic Latex Caulk plus Silicone) to each of the holes. The caulk will shrink and it took 3 applications to completely fill the holes. This will prevent water from standing in the holes and also prevent any ice from forming in the holes (for our northern types, no worries here). So no rust and no plastic cracking.
My bars made a horrid whistling noise at freeway speeds and had a warranty repair for replacing the rubber "spacers" at each end of the bars.
The bars are noisy. They negatively affect gas mileage. They look great!
burlyvue2 is offline   Reply With Quote
Old 03-13-2006, 10:20 AM   #3
jsevinsk
jsevinsk is on a distinguished road
jsevinsk's Avatar
2004 VUE 3.5L
Default Re: Roof Rack Bars Installation 05 VUE
I decided to put Perrycraft DynaSport rails on mine, and then Yakima crossbars. The crossbars can be easily removed when not in use to prevent unnecessary noise and bad gas mileage.
John
jsevinsk is offline   Reply With Quote
Roof Rack Cross Bars Warren 2008 Vue 7 06-29-2008 05:50 PM
Roof Rack-Equinox Cross Bars on a Vue???? tweak89 Vue General 0 04-23-2007 07:40 PM
VUE Roof Rack Cross Bars - Auction saturn-accessor Vue General 1 04-07-2007 01:55 PM
roof rack cross bars Rob Leigh Vue General 31 01-31-2007 10:42 PM
Installing Roof rack cross bars on Vue? k_smoove70 Vue Tech 3 03-14-2002 08:46 AM
