#1 |
![]() Join Date: May 2009
I finally found a replacement door panel for the inside of the driver's door on my '94 SL2. (Old one had the usual arm rest failure.) It's all ready to install, but I can't figure out how to remove the door handle from the inside so I can remove the old panel. It has power locks and windows, if that makes any difference. Any suggestions?
#2 |
#3 |
![]() Join Date: Feb 2009
1997 SW1
The power door locks just add another rod connection from the actuator motor to the lock lever, so there will be three rod connections total - one for the handle that opens the door, one for the lock lever to the locking mechanism of the door, and one from the motor to the lock lever. Then you'll have the one electrical connector for the lock and unlock buttons... worry about that after you have the rods disconnected, because the wire has more slack in it than the rods do. Power windows won't cause you any extra work.
I find it's pretty easy to get the rods on and off if I have a dental hook in my right hand and a flat-head screwdriver in my left hand. You have about 1/2 inch of space to get your tools into, which is just enough to get the dental hook in to pull on the rods and the flathead screwdriver in to push them into place or pull the plastic retaining clips on or off. If you are having a hard time seeing what's going on in there, you may want to use a head-mounted light, as both your hands will be busy. Best of luck!
97 SW1 Auto 174k |
#4 |
here you go buddy this is for the 1st gens
http://www.youtube.com/watch?v=dVloB...e=channel_page if you need anything else on how to just follow the link in my signature. |
#5 | |
![]() Quote:
#6 |
Excellent video, showing all the important details of disconnecting and reconnecting the rods. Thanks! I'll be doing it this weekend.
#7 |
Bookmarks |
Removing inside door panel on 04RL | kakarat | Vue General | 3 | 05-14-2008 04:04 PM |
Looking for a part inside the shift handle. | mrbnice2000 | S-Series Tech | 5 | 01-24-2008 12:14 PM |
Removing the screw behind the door handle (96 SL). | jumbo11 | S-Series General | 4 | 04-09-2005 02:33 PM |
Inside door panel removal? '93 SC2 -- specifically the door handle... | benson500 | S-Series Tech | 5 | 12-06-2004 08:48 PM |
92 SL Inside door handle | Robbie | S-Series Tech | 3 | 06-20-2000 06:31 AM |
