Old 05-29-2022, 10:57 AM   #1
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Default LCA Bolt Availability
Anyone know where I can locate replacement bolts for the front lower control arms?
PN 21010892 is obsolete......
Old 05-29-2022, 10:59 AM   #2
Default Re: LCA Bolt Availability
Usually it says OOS or NLA but it says $5+ s/h
https://www.gmpartsgiant.com/parts/g...-21010892.html
Old 05-29-2022, 11:11 AM   #3
1996SL11.9L
2002 SL1
I did the verify vehicle and it says its replaced by 10273568
Two sites I was on said obsolete with zero options
Thanks!
Old 05-29-2022, 12:34 PM   #4
SRGW
SRGW's Avatar
1997 SL1
Post Re: LCA Bolt Availability
I replaced a lower control arm on a 1995 SL1 and found a replacement bolt and nut at BOLT DEPOT.com
Nut part # 17694 or 12007 12mmx1.75mm Class 10.9 Zinc plated steel.
Bolt Part# 17528 12mmx1.75mmx90mm Class 10.9 Metric Flange Bolt Partial thread.
I am sure that the bolt size did not change over the years.
1995 SL1 236,300 2005>2018
1997 SL1 97,550 2014>????
CHECK YOUR OIL!!
SRGW is online now   Reply With Quote
Old 05-29-2022, 04:10 PM   #5
1996SL11.9L
2002 SL1
I ordered two boltsÖ.
Thanks all.
Old 06-12-2022, 03:59 PM   #6
1996SL11.9L
2002 SL1
Well the bolts came in and they are not what I expected. They are all thread. No shoulder where the bushing rides.
Old 06-14-2022, 12:15 AM   #7
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SW2
Run to Greble U-Pull it in Myerstown PA, I am sure there are a few S-Series there to pick from (I see you are near that area).
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 494,500
1995 Sl2 5spd: Retired Daily, Not Stock: 196,000
1995 Sw2 5spd: Daily, Stock: 105,000
Old 06-14-2022, 11:26 AM   #8
1996SL11.9L
2002 SL1
Been there many times and figured thatís what will happen if needed. Iím expecting to not be able to remove the drivers side bolt.
Old 06-14-2022, 01:04 PM   #9
Thorp
Thorp is on a distinguished road
i just bought some grade 8's from Ace
Thorp is offline   Reply With Quote
'01 SW2 engine coolant drain plug bolt issues and ISO new bolt hangten247 S-Series Tech 7 06-23-2016 10:28 PM
what are the timing belt tensioner bolt and idler pulley bolt torque values goob Astra Tech 4 10-14-2015 08:05 PM
Availability Meum92 L-Series Tech 0 01-16-2013 02:50 PM
Bolt Fairy Strikes! Timing cover middle bolt size? alordofchaos S-Series Tech 8 08-04-2009 11:58 PM
96SL2, broke a valve cover bolt, how to remove the bolt? HomeBase S-Series Tech 6 04-20-2008 12:35 PM
