Go Back   SaturnFans.com Forums > Site Information > Community Center
Old 07-15-2021, 03:48 PM   #1
Adamdrives
Adamdrives is on a distinguished road
Default Hard shifting 2001 SC2
Hello, don't know if this has already been addressed but I am just looking for some help. I have a 2001 Saturn SC2 and the moment I drive the vehicle past 35mph I get a hard shift. I also have a reverse slam that occurs but sometimes goes away it fluctuates. So far I have replaced the Transmission fluid and filled it with 4 quarts, changed the transmission filter, changed the valve body and tested all solenoids for the 4.5-5.0 ohms range, changed the transmission temperature sensor and am now working on the downstream O2 sensor because I have also received this code. The codes I have so far are: PO133 Heated Oxygen sensor slow response bank 1 sensor 1, PO781 1-2 Shift, and P1336 Crankshaft Position CKP System Variation Not learned. I have also replaced the PCM and had it flashed with the dealership before installing the new valve body. Don't know where to go from here as this is my only form of transportation. The fuses are good too because I tested them for continuity. I am now going to try and replace the Crankshaft Sensor to see if it works out. Thanks for the help. Also when I installed the valve body the car was able to go to 70 mph but then hard shifts now past 35 mph and there are no hard shifts in third gear.
Adamdrives is offline   Reply With Quote
hard shift, p1336, po781, reverse slam, sc2 2001
L200 2.2 2001 hard shifting weirdness Solion L-Series Tech 14 05-15-2019 06:59 PM
2001 SL2 MT shifting into gear is hard 00_SL1 S-Series General 4 05-20-2016 06:34 PM
Saturn L200, 2001 hard shifting P0122 code sparky588 L-Series General 1 07-07-2013 10:18 PM
Hard Shifting, Stall Out and Hard Start lswatts L-Series Tech 6 12-11-2008 03:28 AM
2001 SL2 Reverse Slam and Hard Shifting mmore57 S-Series Tech 1 08-30-2008 03:02 PM
