Old 11-29-2022, 03:58 PM   #41
Silverblu02SL2
Silverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the rough
Default Re: Soft brake pedal, went to to floor, leak under driver's seat
My nicop flare next to factory flare, where I really cranked it down and crushed it as far as it will go with a 12" pipe for leverage on the handle.
File Type: jpeg 5CDC8A03-6712-4FC4-8F2F-EAD646D9A772_1_201_a.jpeg (55.6 KB, 39 views)
1/28/2019 2002 SL2 w 62k miles
Silverblu02SL2 is offline   Reply With Quote
Old 11-29-2022, 04:04 PM   #42
Silverblu02SL2
This one I did not crush it as much and is a little thicker, more "bubble" like. I think I'd favor this one over the previous thinner one even though the diameter is smaller but has more material for the flare nut to crush against the mating seat. Which one would you choose or neither one?
File Type: jpeg 8C823170-B5D9-40C3-BB01-03EB45525255_1_201_a.jpeg (28.2 KB, 38 views)
Old 11-29-2022, 04:22 PM   #43
Waiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to behold
The final forming is done by the nut and fitting. Try bolting one of your practice parts to an old hose and then see how it looks.
Edit: they look fine.
Old 11-29-2022, 05:00 PM   #44
Silverblu02SL2
Good idea! Hope my flaring tool will have enough clearance. Inline flaring tools are available for tight quarters. Plan is to fish the 2 straight nicop lines from the rear through it's path up the engine bay with plenty of slack, put on the flare nuts in engine bay, make the 2 flares, make the bends using the old lines as guide, fasten flared lines to the master cylinder, fit the lines into the plastic blocks, make the bends to the rear flex hose unions, cut lines to final length then put on flare nuts and make the 2 remaining flares. I hope there will be enough clearance to make the 2 rear flares with my tool and not have to buy the inline tool.
Old 11-29-2022, 05:01 PM   #45
Why don't you put the nuts on and flare them before you get under the car? Just chuck some blue tape over the end to keep dirt out.
Old 11-29-2022, 05:14 PM   #46
Silverblu02SL2
I thought it may be easier w/o the nuts hanging up on things as I fish the lines through. Maybe not an issue? If so, I'll put the nuts on, flare and tape before getting under the car.
Old 11-29-2022, 06:46 PM   #47
Silverblu02SL2
I think you are right. I don't think my bubble flare kit has a countersink. My old double flare set and my aircraft AN flare set do have a countersink.
My tool with countersink must have been a double flare tool. I wonder if a bubble flare die has a different shape than a double flare die?
Old 11-29-2022, 09:24 PM   #48
Definitely. What dies do you have? If none then it's a single flare tool.
Old 11-29-2022, 10:57 PM   #49
Silverblu02SL2
The smallest die is 1/16". Is the quality of the pic good enough to tell whether the profile of the dish is a bubble flare or not?
File Type: jpeg 0C2DB0F7-DA42-47D2-A2D6-EF9BA5E66922_1_201_a.jpeg (39.7 KB, 40 views)
Old 11-29-2022, 11:15 PM   #50
Looks about right.
Old 11-30-2022, 11:46 PM   #51
Silverblu02SL2
25' roll nickel copper line and flare nuts arrived. Unfortunately the flare nuts are not metric but SAE. The seller says their kit fits Saturn so they must have sent the wrong kit. I'll be reusing the old flare nuts which are still in good shape.
Note the color difference from the roll I bought years ago which I think is CuNiFe which has some iron in it.
File Type: jpeg B05B79B2-8775-409E-A06D-90F1C7A8BEF5_1_201_a.jpeg (124.4 KB, 90 views)
Old 12-01-2022, 10:58 AM   #52
Silverblu02SL2
Looks about right.
What is the angle of the bubble flare for 3/16 (4.75 mm) automotive brake lines? Is it 37 or 45 degrees? How is that angle measured relative to?
Old 12-01-2022, 11:09 AM   #53
I've honestly never seen a specification for the bubble flare. The 37 is aviation.
Old 12-01-2022, 12:12 PM   #54
Silverblu02SL2
Just spoke to tech support at fedhill.com, automotive brake lines use 45 degree flares for bubble (DIN or ISO) and double (SAE) flares. The angle is measured relative to the centerline of the tubing.
https://store.fedhillusa.com/technic...howtopdfs.aspx
Old 12-01-2022, 12:19 PM   #55
Silverblu02SL2
Bryan, is your flaring tool made by OTC and is that a steel line flare made on it?
Old 12-01-2022, 12:45 PM   #56
Bubble flare is mostly just an unfinished double flare. Follow the steps for the double flare, just don't finish it with the countersink. There are specific dies for bubble flare but those kits are usually harder to find, which is just as stupid as metric lines and fittings being hard to find.
If you don't want to worry about the flare, get/rent/borrow a hydraulic flaring tool. I'm never going back to those junk $30ish kits that every parts store sells.
Old 12-01-2022, 02:06 PM   #57
Silverblu02SL2
Yes, a bubble flare is kind of doing 1/2 the operation of a double flare like you said. The widely available and cheap "wing nut" flaring tools vary in quality and precision so it's a crapshoot what you get.
This Capri flaring tool is an interesting unit that has the potential to be a really good tool. The description says it's makes double flares but the video says it does both. The clamp blocks are forged, much deeper, w/o threads that mar the line like the wing nut tools. I like that it is operated with wrenches and not a 5" rod screw handle.
Anyone here have one and can give a review?
https://www.amazon.com/dp/B0859QMSNX...v_ov_lig_dp_it
Old 12-01-2022, 02:38 PM   #58
Yes to both. That was a practice flare on the old line. My OTC tool has done every flare on 2 S Series and a Buick, plus my son has done some lines on friend's cars with it.
Old 12-01-2022, 02:40 PM   #59
Silverblu02SL2
https://www.amazon.com/dp/B0859QMSNX...lig_dp_it&th=1
Scroll down to bottom of page, step 5 "create bubble flare". Question is: Does it create a DIN/ISO compliant bubble flare?
Old 12-01-2022, 03:25 PM   #60
It pretty clearly says it creates an SAE double flare. My recommendation is the OTC tool I linked. My experience runs counter to fetch's.
Edit: your practice flares look fine. Did you try and bolt one of them into a fitting? The nut clamps down on the corner and it's hard to go wrong.
Soft brake pedal. lrbraner Aura General 12 12-01-2020 11:01 PM
Help with soft brake pedal irateb Ion General 18 12-09-2015 10:26 AM
Soft brake pedal? windblownmonkey Ion General 18 05-30-2009 06:32 PM
brake pedal too soft-goes to the floor easily PlasticCarsRock S-Series Tech 10 04-18-2008 09:20 PM
Soft Brake Pedal Gardenof_E Miscellaneous Tech 6 04-15-2003 08:42 PM
