Old 08-14-2021, 03:12 PM   #1
Chicopee L300
Chicopee L300 is on a distinguished road
Default Saturn L300 control arm bolts
First time posting.....
Figured I might save someone some time and frustration...
Wanted to swap out the front lower control arm and balljoint assembly on my 2002 L300 sedan....tried opening the bolts...and yep super tight...so off to my goto mechanic, but to be proactive, knowing the sad story of suspension bolts snapping on removal, I attempted to buy the 4 replacement bolts in advance...
GM 11096192....
Yup Discontinued...1 bolt on ebay...well thats not helpful, so after finding out a version of this car was made under the Opel label in europe, my search widened.
Found an aftermarket offereing.....but...no longer available.
But........it listed the specs and dimensions...
Which in turn helped me find an automovite bolt vendor here in Mass.
The bolt is a grade 10.9 12 x 1.5 mm thread flange head , 90mm long under the head.
I purchased corresponding flanged nuts in case, but turns out the reason they dont show on the exploded view at GM is because they are welded to the chassis.see attached pic of the bolts....vendor online is BellMetric.com.
Hope somebody finds this helpful.
Cheers....Tom.
Chicopee L300 is offline   Reply With Quote
Old 08-14-2021, 08:45 PM   #2
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default Re: Saturn L300 control arm bolts
Bolts are bolts. People get caught up in not knowing that.
Most automotive fasteners are available from other sources.
McMaster -Carr is a great source for fasteners.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Changed Pressure Control Solenoid - 2003 Saturn L300 floridasl22002 L-Series Tech 4 09-11-2018 10:01 AM
2004 Saturn l300 3.0 v6 throttle actuator control issues IRONODIN L-Series Tech 8 09-15-2016 07:11 PM
Control Arms - come with bolts? Good_Apollo S-Series Tech 17 07-20-2016 07:43 PM
2005 Saturn L300 V6 Cruise Control Problem ljwmson Canadian Saturn Owners 1 02-21-2011 05:21 PM
New Control Arm Bolts? txzaphod L-Series Tech 2 10-11-2008 02:20 PM
