#1 |
![]() Join Date: Aug 2014
1998 SW2
* Anyone done this ???
Both 1.9L, Can I swap a 2000 SL1 SOHC into a 1998 SW2 or SC2 DOHC? Both have auto transmissions. Hoping I can just swap the ECM/PCM and engine. Eng too trans should bolt up, Hopefully no wire Harnesses will need swapped out? I can get a rolled 2000 SL1 SOHC for cheep, engine ran great, complete vehicle lots of body damage though! Is it possible to do without a goodies powder? Any help would be great. |
#2 |
You can't swap SOHC->DOHC or DOHC->SOHC and keep the stock automatic. If yours is a DOHC now and you swap to a SOHC you'll have to locate a MP6 if you wish to keep it an automatic.
The proper way to fix a S-Series automatic is to replace it with a manual |
#3 |
1998 SW2
[QUOTE=fetchitfido)- Thanks for the info! I can also get the transmission out of the 2000 model, just a little nervous because the car rolled 3 times! There was no hood damage but there could be vibration damage due to the jarring!
Bookmarks |
Can I swap 2002 DOHC SC Auto trans swap into 2000 SOHC SL? | fbr | S-Series Tech | 3 | 07-17-2014 10:08 PM |
sohc to dohc swap dohc from sw to sl 2002 | MCDOWECT | S-Series Mods | 5 | 06-11-2013 05:06 PM |
sohc to dohc 1.9 swap what should be done | stephen_dykeman | S-Series Mods | 0 | 05-30-2013 11:15 PM |
DOHC TO SOHC Swap!! Not something you see every day! | saturd | S-Series Tech | 21 | 10-07-2009 07:34 AM |
Sohc to Dohc swap | bigbfarm | S-Series Tech | 5 | 08-28-2009 01:26 PM |
