Old 02-19-2016, 08:36 PM   #1
jeepdad
jeepdad is on a distinguished road
Default what to use to adjust headlight?
On my 2002 SL1 I have stripped out the torx inner hole on the up/down stalk for the drivers side headlight adjustment. Is there such a thing as a torx socket that would fit over the outer serrations? If so which should I buy? Or any other suggestions before I strip the outer serrations (whatever you call it?)
jeepdad is offline   Reply With Quote
Old 02-19-2016, 08:40 PM   #2
jeepdad
Default Re: what to use to adjust headlight?
I just found female or external torx sockets. which size do I need to turn the headlamp adjustment stalk for up and down? Thanks!
Old 02-20-2016, 12:54 AM   #3
Pretty sure you're supposed to use an E-7 rather than T-anything. Could be wrong on the E7, pretty sure that's what I used on the new headlights to the '01 SC2 I had.
Old 02-20-2016, 08:36 AM   #4
cdxhizors
cdxhizors has a spectacular aura aboutcdxhizors has a spectacular aura about
1999 SW2
2002 L-Series 2.2L Sedan
Our 95 actually came with a few red screw drivers which were marked "headlight vertical" and "headlight horizontal"
That being said, lube the crap out of the adjustments and use a good e7.
cdxhizors is offline   Reply With Quote
Old 02-20-2016, 11:56 PM   #5
jhonky
jhonky is on a distinguished road
Next ebay headlights i buy will make sure to use e7, thanks forum
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
jhonky is offline   Reply With Quote
Old 02-21-2016, 01:30 PM   #6
cdxhizors
1999 SW2
My eBay headlights use a Phillips. They also broke very quickly as the gear is weak.
Adjust Pop Up Headlight Movement Techpriest S-Series General 6 03-30-2013 08:32 AM
Headlight won't adjust down sps SOHC S-Series Tech 0 09-26-2008 05:32 PM
How to adjust headlight beam? Spartus S-Series Tech 8 07-08-2008 10:53 PM
anyone know how to adjust the clutch 94503 S-Series Tech 7 10-06-2007 07:00 PM
How do I adjust headlight angle on 95 coupe? zallen777 S-Series Tech 6 01-11-2005 10:01 PM
