Old 04-20-2021, 01:39 AM   #21
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
Default Re: 2001 Saturn L300 (L81/3.0L V6) - Intake System + Camshaft Guards [Re-Assembly]
I am jealous of the clean, ready for surgery, engine parts! Few things noticed from the photos.
Did you reinstall the bolt that secured the EGR valve base to the rear engine mount?
Also, what is the long rubber hose routed out and over the front intake module toward the front of the engine? Are you replacing the plastic PVC bridge with this hose? Not a bad idea, those plastic bridges get gunked up.
Rj 2000 LS2 is offline   Reply With Quote
Old 04-20-2021, 12:06 PM   #22
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Thumbs Up Re: 2001 Saturn L300 (L81/3.0L V6) - Intake System + Camshaft Guards [Re-Assembly]
Rj 2000 LS2,
I haven't secured the EGR or mounted it with the new gasket yet. Thanks for noticing! I already replaced the plastic PVC bridge and the hose you are referring to. It's the only route that worked last time and wanted to route it the same way as I had it when it was running good and efficient!
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 04-20-2021, 02:13 PM   #23
Rj 2000 LS2
On the intake side (front of the engine), on the BANK2 side, there is a very small hose that connects intake to a very small module on one of the lower intake's. I think on the injector module. I'm not sure what that is, but it appeared that hose was not connected. There a lot of hose connections after the MAF sensor. Be sure you don't leave anything them disconnected.
Old 04-20-2021, 04:35 PM   #24
BrandonKastning
Rj 2000 LS2,
Thank you for looking. Are you talking about that very small straw like hose that is black near the throttle body? I did manage to get that in later. It's similar to the blue hose for intake on the square black box.
Tags
assembly, intake, l300
2001 Saturn L300 - v6 3.0 Liter - Timing Belt Kit + Camshaft + Crankshaft Seals BrandonKastning L-Series Tech 659 07-26-2021 10:11 PM
2001 Saturn L300 (L81/3.0L V6) - Front Camshaft Cover Gasket [Removal/Replacement] BrandonKastning L-Series Tech 22 04-17-2021 09:12 PM
2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover Gasket [Removal/Replacement] BrandonKastning L-Series Tech 48 04-17-2021 02:12 PM
2001 Saturn L300 (L81/3.0L V6) - Front Camshaft Cover + Front Guard/Mount [Removal] BrandonKastning L-Series Tech 17 04-10-2021 09:20 AM
2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover + Rear Guard/Mount [Removal] BrandonKastning L-Series Tech 15 04-07-2021 01:04 AM
