Old 03-17-2021, 02:47 AM   #1
jasenpeters
jasenpeters is a jewel in the roughjasenpeters is a jewel in the roughjasenpeters is a jewel in the rough
jasenpeters's Avatar
Default Dashboard Crack Repair?
Anyone find a good method of repairing cracks (short and long) in the dash?
I would figure some type of bonding that works with Saturn plastics, sanding for smoothing and painting if possible (or worth it).
I can't remember if the the top part of the dash (what I normally call the dashboard) is fully replaceable.
Even from a junk yard it may come with it's own problems and probably not worth the time.
I once tried to remove the soft squishy front part of the dash (surrounds the glove box and instrumentation bezel), but it turned into a nightmare and just wouldn't seem to let go, so I abandoned the attempt at removal (it was a junker I was trying to remove it from to replace my current one.)
That attempt was over 10 years ago, the cracks are now from end to end, mostly in the direction of windshield to radio console (front to back).
I guess from heat over time.
I'm even considering a veneer cover like a cloth cover or headliner material.
Any suggestions are appreciated.
Re-Animated: 2015-08-18, 220,497 + 21,000 Miles
1996 SC2 DOHC, Manual, 220k, 36mpg Hwy
jasenpeters is offline   Reply With Quote
Old 03-17-2021, 08:57 AM   #2
Waiex191
Waiex191's Avatar
Default Re: Dashboard Crack Repair?
One issue you are likely to have is cracked mounting tabs.
http://www.saturnfans.com/forums/sho...&postcount=245
But yes that part is removable.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 03-17-2021, 05:36 PM   #3
It's just prying off the screw covers and a couple of screws, then it pops off (don't lose the rubber strip where it meets the glass)
http://www.differentracing.com/tech_...99cluster.html
Not 100% positive but pretty sure any 2nd gen interior would fit (you could probably test fit a sedan or wagon dash top with a coupe at the junkyard if there are enough cars there)
Guessing all that foam and vinyl covering the dash parts is glued on, possibly heat shrunk?
Old 03-18-2021, 02:07 PM   #4
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Best you can do is to stop drill existing cracks so they donít grow. Not really any virgin dashboards left.
Old 03-19-2021, 10:53 AM   #5
Even if you repaired it, you'd have to sand the texture off the entire dash pad or have someone with some artistic ability go nuts with a die grinder on the repair area.
Sun fading could change the color some, but I believe 2nd gen only had 2 colors...black and tan. Possibly a blueish grey kind of color, but I think that was mainly a 1st gen color.
Tags
cracks, dashboard, repair, replacement
Oil pan crack 3.5L? RobertGary1 Vue Tech 1 06-28-2020 09:16 PM
Crack in block!!!!!!! PSDFan S-Series General 21 10-16-2013 01:18 PM
So why does a head crack? 1.9 sohc S-Series Tech 41 05-03-2012 11:41 PM
dashboard rattle.. repair manual? wonderif Aura General 0 08-19-2008 08:53 AM
Fender Crack Repair? VEGAS_SATURN S-Series Tech 3 05-23-2006 12:00 AM
