Old 10-31-2020, 12:06 PM   #1
seansaturn
seansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of lightseansaturn is a glorious beacon of light
seansaturn's Avatar
Dizzy Car Rear End Knocking 20-55mph (Saturn Vue AWD 3.5L 2007)
Hi,
I am wondering if somebody knows what this hollow sounding knock is? From inside the cabin, it sounds like somebody is knocking on the body of the car. From underneath the car, it sounds like a slight clattering sound.
I made a video here from 3 different places and edited it all together. See here: https://youtu.be/x0uVS3nNhtY
It doesn't 'seem' to have any notable pattern or become worse/better with cornering. When I hit the freeway at 65mph+, the problem goes away completely; not one single knock. It doesnt 'seem' to change pattern or pitch with road bumps.
Symptoms:
- Hollow knock from rear end. Driving doesn't appear to be affected.
- 20-55mph it seems. Freeway driving has no knocking at all
What I have noticed:
- Exhaust components look sturdy. I have shook it in various places, cannot reproduce any sound
- Drive shaft is not currently present/installed. I removed it 3 weeks prior.
- Cannot re-create noise at full stop by pushing car up and down
or shaking the car/wheel side to side. I jumped up and down on the rear bumper. It seems really smooth. I also pushed the car side to side and also grabbed each rear wheel and shook them side to side. I cant seem to make any noise.
- Rear axle nuts are tight
I was going to tie a Go Pro underneath so I could see a bit better. I will do that if I can't figure it out to try and get a better look around. I didn't fancy putting my phone on a selfie stick and poking it under the car at speed.
Thanks for help in advance
Saturn Vue 2007 AWD 3.5L V6 - Honda J35S1/GM L66 Engine
GinkoSolutions.com
seansaturn is offline   Reply With Quote
Old 11-02-2020, 03:44 PM   #2
SL2 Ride
SL2 Ride is a jewel in the roughSL2 Ride is a jewel in the roughSL2 Ride is a jewel in the roughSL2 Ride is a jewel in the rough
2005 ION-3 Sedan
Default Re: Car Rear End Knocking 20-55mph (Saturn Vue AWD 3.5L 2007)
Is the Vue an AWD model?
SL2 Ride is offline   Reply With Quote
Old 11-02-2020, 04:04 PM   #3
seansaturn
seansaturn's Avatar
Yes, its in the post title already and in my sig also
GinkoSolutions.com
Old 11-02-2020, 06:35 PM   #4
atikovi
Sounds like exhaust tapping the frame. If it has a sway bar, check the links and bushings.
Old 11-02-2020, 11:59 PM   #5
seansaturn
seansaturn's Avatar
I thought the same thing about the exhaust
I have shaken the exhaust like crazy, its not touching anything.
The rubber exhaust clips are all in tact and strong.
The sway bar, both rubber mounting bushings are really good.
The sway bar links have some gaps in them. I think that might be it!! It looks like a gap of 7mm or so on the drivers side and 3mm on the passenger side. No idea how these got there unless the boot squished inward I have no idea how that could have happened. I tried to tighten the nut down with an allen key in the end but it wont budge. The rubber looks a little worn on the bottom from the dry heat here, so i think ill order a set and see if that fixes it!
Thank you for the suggestion. I've been crawling over this car and shaking everything like crazy for a couple of hours or so. I guess I didnt look hard enough.
I'll update soon
GinkoSolutions.com
Old 11-03-2020, 09:16 AM   #6
SL2 Ride
2005 ION-3 Sedan
I have sigs turned off, anyway there's a bearing that eventually goes bad on the drive shaft that could start knocking over time.
Old 11-03-2020, 10:06 AM   #7
atikovi
Except,
Old 11-03-2020, 09:10 PM   #8
SL2 Ride
2005 ION-3 Sedan
Originally Posted by atikovi View Post
Except,
Ah yeah, I see. So was it knocking before he pulled the drive shaft? Like maybe it's coming from the differential?
Old 11-04-2020, 03:49 PM   #9
seansaturn
seansaturn's Avatar
What is going on? I'm really confused by your mis-understanding. Are you trolling me?? lol
1.Video title says: Dizzy Car Rear End Knocking 20-55mph (Saturn Vue AWD 3.5L 2007)
2.Drive shaft is not currently present/installed. I removed it 3 weeks prior.. Prior means before, you know, before the symptoms.
3. Then I mentioned above that I found gaps in the sway bar links and I would report back
I think i've been had here!
GinkoSolutions.com
Old 11-04-2020, 10:07 PM   #10
SL2 Ride
2005 ION-3 Sedan
I don't see the update anywhere? Are you saying you found the problem? If so you could inform us, and I'll stop thinking about the possibilities.
Old 11-05-2020, 01:12 PM   #11
seansaturn
seansaturn's Avatar
http://www.saturnfans.com/forums/sho...28&postcount=5
Please read above. Its already been mentioned.
GinkoSolutions.com
Old 11-06-2020, 01:16 PM   #12
SL2 Ride
2005 ION-3 Sedan
Let me help you with the part you seem to keep missing:
"I'll update soon".
Old 11-07-2020, 01:11 PM   #13
Cavell
My kid has a rear broken coil spring. I think 1 end loop is snapped. Barely effects ride height. And I think 1 of the rear sway bar links is broke? I believe it is plastic? Kinda forget after doing all 4 wheel bearings. Ordered front links for my ride. 1 is gm and is about 1/2 dia bar? Was on discount for $6. The other is std quality and it is 3/8 dia? Seems like a toy. Glad I did not get the economy model.
File Type: jpeg 7048B823-C737-452A-B1B9-70CB50FB8AF8.jpeg (40.5 KB, 9 views)
Old 11-07-2020, 03:15 PM   #14
SL2 Ride
2005 ION-3 Sedan
Broken spring tips is one of the things I was going to suggest for op.
Old 11-09-2020, 01:08 AM   #15
seansaturn
seansaturn's Avatar
Installed two new stabilizer bar end links, works a treat! Thank you!
Something useful for others:
The OEM links have a 6-point torx 27 hole to keep the bolt steady in the knuckle. I only had 12 point torx allen keys which didnt fit without ruining my bits. But I did have a 6 point t-27 bit for a cheap screwdriver. So I put the hex end of the bit into a 6.5mm standard hex socket which fits snug, and then used my socket wrench to keep it still.
When replacing both links, I loosened the 15mm bolts on the insulator brackets of the stabilizer bar. That allowed me to attach the links evenly at each without any stress on the insulators.
"I'll update soon".
I said that on the 2nd nov, its now the 8th nov. In that time, I have to: order parts, wait for them to arrive, find a day with good weather and then install them I have family, kids, pets, work... Something to consider before making snide remarks. I could make a return dig about you not reading post titles, asking questions which have been addressed in the OP and threads later on and randomly ranting on, but I just don't have the time nor patience.
GinkoSolutions.com
Old 11-11-2020, 10:27 PM   #16
SL2 Ride
2005 ION-3 Sedan
lol, so self unaware.
Old 11-18-2020, 01:58 AM   #17
Bismarck318
Bismarck318 is a jewel in the roughBismarck318 is a jewel in the roughBismarck318 is a jewel in the rough
Location: Birthplace of Rust, FKA The Heart of the Rustbelt, AKA The Angry White Planet Ohth
2001 L-Series 3.0L Wagon
Hi,
Unlike mine has a pattern.
Oscillating thudding Right Rear
Clean underneath...
I had the heat shields also clattering. Impressive video, where did you find a daredevil to hang under the car, I need to borrow him!
Angry White Planet Ohth.... The REAL "Salt Life"!
Tags
knocking, noises, saturn vue 2007, saturn vue 3.5l
2007 Saturn ION 2 with Clicking Rear Drum Brakes ThePaleEmperor Ion Tech 2 07-25-2016 01:08 AM
2007 Vue 4 cyl with random knocking sound in rear fatstrat Vue Tech 4 06-18-2015 11:57 AM
2007 ion rear brake knocking dlacacres Ion Tech 10 09-01-2014 09:10 PM
rear end vibration 55mph briansc1 S-Series Tech 2 09-18-2008 10:05 AM
2007 V6 Vue with 1000Km and engine knocking? Please help. riller Vue Tech 6 08-24-2007 09:16 AM
