Old 09-21-2020, 10:46 PM   #1
GL4202
GL4202 is on a distinguished road
2002 SL
Default Raised hood, ventilation?
I just recently added spacers to the hinges for the hood to raise the back up about an inch, then I realized that the cabin air intake is right there under the windshield wipers. Im worried about funes or something going from the engine bay into the cabin. Is this safe? Will I be inhaling anything I shouldnt be? Or will it just be hot air?
GL4202 is offline   Reply With Quote
Old 09-22-2020, 04:00 AM   #2
454cid
Default Re: Raised hood, ventilation?
That was popular in Japan a few years ago, I've read.
You may have cooling issues, since the base of the windshield is a high pressure zone, you'll likely force air into the engine bay making it harder for the air to come in through the radiator.
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 09-22-2020, 11:11 AM   #3
billr
I gotta ask... what is the purpose of lifting the rear of the hood???
Old 09-22-2020, 11:25 AM   #4
trottida
trottida's Avatar
It's usually done to accommodate raising the engine (engine mount spacers) as part of lowering the car. If you don't raise then engine your axle life is compromised. When you raise the engine the hood touches so you lift the back to accomodate.
1999 SL2 MT (298,000 km @ 06/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 09-22-2020, 02:41 PM   #5
454cid
I've never heard of that, it's always been guys trying to "let the hot air out", in my experience.
1999 Chevy K3500
Old 09-22-2020, 02:43 PM   #6
hholbein
1997 SW2
Dazed Re: Raised hood, ventilation?
Jeez, I thought these cars *were* pretty low to the ground. IIRC, there's also some safety hooks on the back of the hood that are intended to add crumple energy to the hood in a front-end collision. But if you're a Safety Last guy, go for it!
Old 09-22-2020, 05:14 PM   #7
trottida
trottida's Avatar
The seat position is low to the ground. The car itself seems to have pretty decent ground clearance. Much better than my Ford Focus; it scrapes bottom on the road into our cabin where the SL2 does not.
I think the reasoning for lowering an S Series is to eliminate tire gap between the top of the tire and the body. I agree it does look better however I'm not willing to lose any ground clearance.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 09-22-2020, 07:07 PM   #8
td1238
When testing the air conditioner pressure, you put the system on recirculate to avoid sucking hot engine air into the evaporator, since the hood is open. This can cause excessively high ac issues. You may have cooling issues if the rear hood gasket leaks.
Old 09-22-2020, 08:43 PM   #9
GL4202
2002 SL
Yeah thats what I think it does, at idle it lets the hot air vent out, and im gonna put a diy mightycarmods splitter on it, so there will be a low pressure zone under the car, and high pressure zone at the back of the hood. Air will get pushed down under the car
Reversing it if the cabin air intake takes in bad air though. Not worth more lung damage lmao
Tags
cabin, hoodraise, hvac, ventilation
2001 SC2 Ventilation Fan rustyray S-Series Tech 3 09-17-2019 10:27 PM
Ventilation question MikeNW S-Series General 1 04-08-2009 08:00 PM
Raised front seats! danielni S-Series General 2 10-16-2005 03:16 PM
SC2 ventilation Malak S-Series General 5 03-25-2004 05:50 PM
Ventilation in 2000 SL1 asbasb S-Series Tech 5 07-20-2000 10:07 AM
