Old 05-30-2020, 09:12 PM   #1
BrandonKastning
BrandonKastning will become famous soon enough
BrandonKastning's Avatar
2001 L-Series 3.0L Sedan
Wrench 2001 Saturn L300 - v6 3.0 Liter - Timing Belt Front Cover (Questions w/ FSM Diagrams)
This first post will contain pictures of my timing belt front cover and it's oil contaminated/compromised state.
I am hoping to determine the following from this thread.
1) Does anybody have actual photos of what I am looking at and the inside of the cover?
2) Does the cover protect the timing belt from even oil spills into the holes that I have circled in my pictures where oil have contaminated and possibly compromised the state of my timing belt?
3) The FSM shows the cover; I just do not see any "divider" that would protect like a tray on the top of the timing belt front cover; so that oil doesn't leak/drain into the timing belt system.
4) If there isn't a cover that protects it and my timing belt insides are oil filled. Then I must fix all of this before diving into a head gasket replacement in my opinion otherwise I do not feel it's worth moving forward with to secure my block.
The remainder posts are the Factory Service Manual pages for this part of the engine.
Any pointers would be helpful!
“For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.” - John 3:16 (KJV)
BrandonKastning is offline   Reply With Quote
Old 05-30-2020, 09:13 PM   #2
BrandonKastning
Wrench Re: 2001 Saturn L300 - v6 3.0 Liter - Timing Belt Front Cover (Questions w/ FSM Diagr
FSM Gallery 1/3: Timing Belt Cover
Old 05-30-2020, 09:14 PM   #3
BrandonKastning
FSM Gallery 2/3: Timing Belt Cover
Old 05-30-2020, 09:15 PM   #4
BrandonKastning
FSM Gallery 3/3: Timing Belt Cover
Old 05-31-2020, 05:53 PM   #5
Default Re: 2001 Saturn L300 - v6 3.0 Liter - Timing Belt Front Cover (Questions w/ FSM Diagr
1st post/1st snapshot - two piece plastic covers for the cam position sensors wiring. Compare this snapshot to last post/1st snapshot/bottom page drawing. The two piece covers are meant to encase the small wires from damage, nothing more. Oil, dirt, grease, water and debris can enter but will not harm wiring. Holes underneath may provide a drain path. The red circled areas are showing the snap together tabs and other (vent?) holes.
1st post/2nd snapshot - power steering pump. The red circled area is a fitting. Oil and dirt covering the pump is from an unknown source.
The timing belt/camshaft cover is directly behind this convoluted harness cover. If the timing belt cover isn't damaged, it shields the timing belt against fluids, dirt and grime. A seal around the cover prevents fluid intrusion. Everyone performing their own timing belt replacement, including me (@100k mile intervals) and posted snapshots have never seen fluids enter past the cover.
Old 05-31-2020, 06:31 PM   #6
BrandonKastning
Thumbs Up Re: 2001 Saturn L300 - v6 3.0 Liter - Timing Belt Front Cover (Questions w/ FSM Diagr
Is this an easy piece to remove? Mounting bolts are required to be removed?
Thank you for letting me know what that is! That will be helpful in finding the best method for me to clean it up.
I was reading one of your timing belt threads and I didn't see screen shots. Perhaps you have more than one thread in regards to your job you did last year. If I recall it was November / 2019 ? Not understanding what a timing belt does; it read like it's absolutely critical to perform properly without ruining your engine. I also read that you utilized a different tool rather than a kit.
I feel since oil has been everywhere it would be wise to look. Are there any dangers or concerns that I should note ahead of time before opening up the protective case to check to make sure the timing belt cover is in good condition?
Thank you for the response fdryer!
~ Brandon
Old 05-31-2020, 08:22 PM   #7
As I stated in that thread, other members already posted snapshots of their timing belt procedures like;
http://www.saturnfans.com/forums/sho...lt+replacement
http://www.saturnfans.com/forums/sho...d.php?t=114197 (excellent thread)
I used 'L300 Timing belt replacement' in the advanced search feature and scrolled thru the list, concentrating on titles using 'timing belt' and a paperclip symbol to the far right of each titled thread to indicate snapshots or drawings.
It's apparent to some of us that you're not familiar with engine configurations. There are two configurations related to the mechanical portions of 4-stroke engines; gear or timing belt driven camshafts. Ferrari and many other engine manufacturers use gear driven camshafts for relatively trouble free engine operation. In lieu of gears, engines like our L300s use one timing belt. They're life limited to 100k miles when it's recommended to replace it. One member allowed his engine to surpass (around) 145k miles before replacing it. Not replacing it as recommended is gambling on it falling apart resulting in immediate damage to the engine. Whether gear or belt driven, camshafts must be mechanically synched between crankshaft and camshafts otherwise pistons crash into valves instantly while it's running. Catastrophic damage. Basic mechanical skills are needed to follow service manual procedures and not for the faint hearted as this is advanced repairs not recommended for the average diyer unfamiliar with engine timing basics. Service manuals are written for dealer mechanics already familiar with repairs, not for diyers without knowledge. Special tools are needed while advanced diyers came up with several ideas to lock camshafts in place without these tools.
Old 05-31-2020, 09:44 PM   #8
BrandonKastning
fdryer,
Thank you for the kind education and the links to the excellent thread to learn more! Much obliged!
Tags
2001 l300 timing belt, 2001 saturn l300, 3.0l v6 timing belt
2001 Saturn L300 - v6 3.0 Liter - Alternator (I didn't install it correctly) ? BrandonKastning L-Series Tech 41 08-14-2020 01:41 PM
2001 Saturn L300 - v6 3.0 Liter - Broken Mounting Bolt BrandonKastning L-Series Tech 33 06-30-2020 10:03 AM
2001 Saturn L300 - v6 3.0 Liter - Seafoam in crankcase housing? BrandonKastning L-Series Tech 20 05-05-2020 08:37 PM
2001 Saturn L300 - v6 3.0 Liter - Won't stay running after a breakdown and bad... BrandonKastning L-Series Tech 502 04-25-2020 01:10 PM
2001 Saturn L300 - v6 3.0 Liter - STINGER Isolator 200 AMP + Auxilliary Power BrandonKastning L-Series Tech 28 03-14-2020 06:32 PM
