Old 04-25-2016, 08:18 PM   #1
jthommarson
jthommarson is on a distinguished road
Default Looking at a 2007 Vue 3.5 AWD
Decently priced 2007 Vue for sale near me. I have a 2000 SL and I really like the Saturn brand. I really like this one because of the Honda power train. I test drive it today and it's a nice driving car. Seems to have a good bit of get up and go. That being said, what should I specifically look for as far as issues? I plan to ask dealer about timing belt/water pump tomorrow. It has 93K miles. AWD probably not abused as it is in NC.
THANKS!
jthommarson is offline   Reply With Quote
Old 04-25-2016, 09:51 PM   #2
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Default Re: Looking at a 2007 Vue 3.5 AWD
Jthom,
The only other things to look at are has the trans been serviced per Honda specs or not at all??? It needs to be done per Honda spec, drain and refill with Honda fluid only. Then check out the service of the RDM/ rear diff with Versatrak fluid. I love my 07 3.5, and you are right... They do sorta scoot pretty well. And that scoot can sneak up on you kinda quick.
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
lord_varon is offline   Reply With Quote
Old 04-26-2016, 07:04 AM   #3
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Know the AC is a trouble spot. Make sure the AC is cooling correctly. Not sure if it was mentioned but timing belt
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
underthehood is offline   Reply With Quote
Old 04-26-2016, 06:55 PM   #4
flyingj
flyingj will become famous soon enoughflyingj will become famous soon enough
flyingj's Avatar
Also, get under the Vue and look at the center support bearing on the driveshaft. Make sure the rubber is in good condition (or there at all). You can also look for rust while you are under there. The sub-frame under the engine is the most likely place to find rust if there is any.
If you do buy it plan to replace all the fluids (oil, coolant, transmission fluid, RDM fluid) so you have peace of mind that it was done. If there is not good documentation for the timing belt and water pump replacement, then I'd budget for that in the next year. Other than that, enjoy! They are fun little boxes.
2001 L-200 2.2l
DOB: 05/08/01 Owned: 07/01/07 to 10/30/18
2006 Vue 3.5L AWD Mileage: 145,000
DOB: 08/24/05 Date Acquired: 12/15/06
2019 GMC Acadia (aka Saturn Outlook)
flyingj is offline   Reply With Quote
Old 04-28-2016, 05:49 PM   #5
jthommarson
Well I did it. Nice little ride. Got it for way under MSRP. I plan on a fluid change this weekend. And budgeting for timing belt and water pump.
Old 04-28-2016, 05:53 PM   #6
ryan_g
ryan_g is on a distinguished road
2004 VUE 3.5L
Are you planning on doing the timing belt yourself or taking it to a shop?
ryan_g is offline   Reply With Quote
Old 04-28-2016, 05:57 PM   #7
jthommarson
Probably do it myself. I have extensive mechanic experience. Speaking of, I guess I need to get to changing that intake gasket on the ol SL.
Old 04-28-2016, 06:00 PM   #8
flyingj
flyingj's Avatar
Congrats! Enjoy it.
2001 L-200 2.2l
Old 04-28-2016, 06:08 PM   #9
ryan_g
2004 VUE 3.5L
Just curious. I did mine myself also and it wasn't bad. The bolt that holds the crankshaft pulley on is a PAIN! Make sure you have the tool for it.
Tags
3.5, awd, vue
Vue Leads Equinox in 2007 Sales as of 7-1-2007 mikec Vue General 2 07-06-2007 06:52 PM
Vue Leads Equinox in 2007 Sales as of 2-28-2007 mikec Vue General 6 03-13-2007 04:42 PM
MSN Users Rate 2007 VUE over 2007 Honda CR-V BobbyP Vue General 14 02-26-2007 01:54 AM
MT Fluid Usage In 2007 And Prior MTs And TCs (02/05/2007) asdf S-Series Tech 0 02-16-2007 02:55 AM
2007 Aura XR vs 2007 2.0T passat sedan, which to buy? fantarain Aura General 43 11-26-2006 12:39 PM
