Old 07-03-2010, 03:47 PM   #1
snhaller
snhaller is on a distinguished road
Sad SES light flashes and cranks while trying to start
Have had the should-be-addressed-by-GM-but-they-won't-take-responsibility-for-it "won't start in cold weather" problem for about 8 months. Happens at least once a week. I wait 10 minutes exactly and it starts fine.
Got a WA state-required emissions test done 2 days before we left for our wedding in CA. Passed that. No issues. I can't remember if I had driven the car after the test before we left for the week. Car was left in our condo complex.
Tried to start my car today, but when I tried to turn the key, I got an awful cranking sound and the Service Engine Soon light flashing at me. Radio works. Lights work. Doors lock. Car refuses to start.
I took video of it, as I'm having trouble finding similar problems when googling. Since I'm new, it won't let me post the video, but my username on youtube is snhaller.
Yesterday, we had the same "won't start" problem as normal, but we ended up taking our other car as we had an appointment to catch. Problem didn't sound or act different.
I'm overdue for an oil change but don't think that's it. Any suggestions as to the reason? Don't you love when car repairs seem to happen at exactly the worst time? Unemployed and we just married, which was planned way before I lost my job.
GM says the nearest dealer to us is in Kirkland, WA and is 15 miles away, so a tow will be pricey, too.
2005 Ion 2. 58k miles on it.
snhaller is offline   Reply With Quote
Old 07-03-2010, 04:45 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: SES light flashes and cranks while trying to start
that sound means your battery's dead. this is not GM's fault. replace your battery.
make sure you get a proper VENTED battery from GM, any non vented battery is BAD.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 07-03-2010, 05:22 PM   #3
2006 ion2
2007 ION-2 Sedan
it may also be your starter, try jumping your car to determine which it is, but my bet is it's the battery. and it's definitely not your ignition switch.
2007 Saturn Ion 2
Old 07-03-2010, 05:33 PM   #4
2006 ion2
2007 ION-2 Sedan
oh, and I am speaking from experience, I have had various causes drain my battery down in my ion to various states of discharge
2007 Saturn Ion 2
Old 07-04-2010, 01:01 AM   #5
2006 ion2
2007 ION-2 Sedan
the funny thing is, ions sound exactly like that when the battery is too dead to crank the starter, and if it's been doing this for 8 months, your battery is toast, so it needs to be replaced, it could be your starter, but if it is your starter, hooking up some jumper cables will give you a good idea, because if you get anything more than what you have now from the jump, it's most likely your battery. checking grounds and positive leads at your starter, battery, fuse block, and alternator would not be a bad idea. just because you don't think it's feasible doesn't mean it isn't the problem.
2007 Saturn Ion 2
Old 07-04-2010, 01:15 AM   #6
snhaller
Thanks, guys.
I had figured since it was the service engine soon light instead of the battery light, that it was something different.
And this is a completely different sound than the usual problem of not starting when it cold - so I was figuring it wasn't the ignition switch.
Tags
emissions, flashing, ion, ses light, start
Coolant Light Flashes Off and On CarPoorDad S-Series Tech 4 07-02-2008 01:37 PM
security light flashes??? raychris1 Vue Tech 4 06-21-2006 03:35 AM
Water temp light and another light flashes then stops CBXweb S-Series General 6 11-11-2005 02:29 PM
Radio Light Flashes RadioRon S-Series General 5 11-14-2004 12:02 AM
ABS light flashes when car starts moving nanotek2018 S-Series Tech 2 08-12-2004 02:36 AM
