Old 02-12-2010, 03:11 PM   #1
Kurtduane
Kurtduane is on a distinguished road
2005 ION-3 Sedan
Default Flashing/Resetting Dashboard
I am experiencing a very bizarre problem with my 05 Ion. My dashboard lights, and gauges are flashing on and off while I am driving. I am not experiencing any performance issues even though the display is showing the Trac is disabled and power steering. It is acting like it is resetting or even like some connection is loose. Any thoughts?
Kurtduane is offline   Reply With Quote
Old 02-12-2010, 04:07 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Flashing/Resetting Dashboard
check: the battery and alternator cables and the IP connector
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 02-12-2010, 06:03 PM   #3
Kurtduane
2005 ION-3 Sedan
Battery and alternator are fine...explain IP conductor.
Old 02-12-2010, 06:18 PM   #4
2006 ion2
2007 ION-2 Sedan
not the battery and alternator, the cables, for being loose or really corroded, this was my problem when this happened to me. not the conductor, the connector. take the IP out and check the connector and socket on the IP, then re seat the connector and try it.
2007 Saturn Ion 2
Tags
dashboard, flashing, gauges
Resetting OLM markak15 Astra General 3 06-18-2009 09:12 AM
Resetting the BCM marx404 Astra Tech 3 11-17-2008 11:02 AM
Resetting your OLM btrfl1562 Ion Tech 1 01-13-2008 11:08 AM
resetting ecu/pcm veritasconnor S-Series General 5 01-05-2006 02:25 AM
Resetting PCM dcamden Miscellaneous Tech 3 04-29-2004 02:03 AM
