Old 03-01-2014, 12:15 PM   #1
jcumens
jcumens is on a distinguished road
1999 SL1
Dizzy 1999 Saturn SL1 TAAT Soleniod Compatibility
I will be replacing the Transmission TAAT solenoids for my 1999 SL1 (250K Miles). The supplier I am choosing for these solenoids claims that his solenoids are compatible for all SL1 models from 1992-2002. The set of 5 solenoids he is providing seem to be identical. I bought the the car new in 1999 and have the original 4 volume set of GM shop manuals.
I have 2 questions:
Question 1: The shop manual mentions that a solenoid valve set has 2 types of solenoids in a single set. One type is extracted by twisting it. The other type pulls straight out. Are all 5 solenoids the same as the supplier claims? The videos that I have seen on the solenoid installation also seem to indicate that all 5 solenoids are identical.
Question 2: Are the solenoids the same for all SL1 models from 1992-2002 as the supplier claims?
Obviously I am trying to avoid surprises before I buy the solenoids and pull apart the valve body!!
Thank you in advance for your help!!
jcumens is offline   Reply With Quote
Old 03-01-2014, 02:03 PM   #2
Default Re: 1999 Saturn SL1 TAAT Soleniod Compatibility
Later ones have a screen on the ports below the coil. As long as they came out of any later Saturn they are all swappable. The solenoid coils have a lifetime and the older ones are more prone to failure.
Old 03-01-2014, 02:32 PM   #3
jcumens
1999 SL1
Thank you for your help!
What a relief!
1999 sl1, solenoid, taat
1999 SL engine swap compatibility with 2001 J302 S-Series Tech 12 07-19-2010 03:32 PM
subframe compatibility? 2000 sl2 to 1999 sl1? stlmike S-Series Tech 5 03-03-2010 03:10 PM
1999 SL SOHC engine compatibility and PS compatibility rich_d S-Series Tech 6 01-10-2010 06:10 PM
auto trans soleniod 97sl2DOHCaut1.9 S-Series Tech 12 10-05-2008 11:59 AM
Checking EGR soleniod? Dach Miscellaneous Tech 3 10-13-2002 06:14 PM
