Old 08-19-2021, 02:58 PM   #1
SelfemploydL200
SelfemploydL200 will become famous soon enough
SelfemploydL200's Avatar
2002 L-Series 2.2L Sedan
Idea 02 L200 No Brakelights Culprit!
So, today this morning I finally got around to looking at my rear bulbs. Carpet back, disconnected all related wiring to avoid anything going haywire as I was fiddling with the bulbs and examined them.
Upon inspecting the bulbs I noticed the following:
Both sockets appeared to have burned contacts (on each socket, one contact was burned) and in turn the contact on the bulb was burned, and I'm assuming, leading to no brakelights!
Picture attached is a rough drawing of what it looks like.
Will get real pictures soon but my fingers are worn out from prying the darn bulbs out.
I remember someone on here saying the sockets were faulty so perhaps this could've happened because of them?
2002 L200 "Rattler" 68,xxx - December 2021 (Mileage As Of Memory)
2006 Kia Sorento EX 97,xxx - December 2021 (Mileage As Of Memory)
1989 Toyota Van CRG 269,xxx - December 2021 (Mileage As Of Memory)
SelfemploydL200 is offline   Reply With Quote
Old 08-19-2021, 10:03 PM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
Default Re: 02 L200 No Brakelights Culprit!
That is common to all brands however it is usually the taillight circuit that is burned. Our company policy is to burn all the lights to be seen. So every 5000 hours of run time or so the sockets melt out.
2002 L200/5 Loaded, over 1/4 million miles!
Old 08-20-2021, 09:52 AM   #3
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
There was a recall issued for some earlier years of L Series.
I believe it involved a improved tail light socket
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
lrbraner is offline   Reply With Quote
Old 08-22-2021, 04:44 PM   #4
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
Actual pictures would help drawings aren't going to show what's damaged.
Old 08-28-2021, 01:39 PM   #5
bromli
bromli is on a distinguished road
bromli's Avatar
Had the same thing on mine a couple years back. Only solution was to replace the sockets entirely. Luckily its pretty easy to get them in and out. There was a recall for this on 00-04 models, so its a known issue.
bromli is offline   Reply With Quote
Old 08-29-2021, 12:13 AM   #6
SelfemploydL200
Sanded down the burnt contacts and got some new bulbs. Temporary fix until I find some better sockets. Also, learned not too hold down the brakes for 30 or so minutes when in extended stopped periods; just put it in N/Handbrake
Tags
brake lights
02 L200 No Brakelights SelfemploydL200 L-Series Tech 10 08-05-2021 11:19 PM
Water Leak in VUE- Likely culprit? joshjani Vue General 3 02-24-2019 03:24 PM
Think my cv joint is the culprit? pippo S-Series General 28 11-09-2009 12:01 AM
No Brakelights! OFC Engine 4 S-Series General 7 04-03-2007 11:50 AM
Are brakelights (The Bulbs) coverd under warrenty? woowoo General Saturn Discussion 10 01-30-2003 04:23 PM
