Old 04-29-2020, 08:07 PM   #1
Hiisi
Hiisi is a jewel in the roughHiisi is a jewel in the roughHiisi is a jewel in the rough
Hiisi's Avatar
Default Another engine cradle topic
Hello, folks!
I hope everyone finds themself healthy and morally strong during these historical times.
I plan to replace the engine cradle on my 98' SL2 this weekend. Any advice? Could you please drop the links in the comments on the threads you wish you would have read before doing this operation? I plan to use some 2x4 pieces of wood to hold the engine (the gearbox needs to be fixed in place I assume). Any advice or just your thoughts if you are feeling bored is much welcome. I'm a little bit nervous doing this on the cobblestone slopped street where I live with the minimal tools available
Hiisi is offline   Reply With Quote
Old 04-29-2020, 08:27 PM   #2
trottida
trottida's Avatar
Default Re: Another engine cradle topic
Blast the heck out of the bolt retainers with a penetrant for a few days. They are tucked up within the engine cradle and sometimes break free when you turn the bolt. This makes it much harder to deal with as they are not in a favourable spot for access with tools.
Use a impact gun if possible.
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 04-29-2020, 08:48 PM   #3
Hiisi
Hiisi's Avatar
Solid point! I have inspected them and they look surprisingly well compare to the rest of the suspention bolts. But of course I will blast them with all available chemistry.
Sadly I have no impact driver. But I do have a long pipe that fits well on my tools.
Old 04-29-2020, 09:59 PM   #4
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Have some vice grips ready if one of the retaining clips does break. Even with penetrating fluid, they tend to rust out over time and bend when you put torque on it. I had one break when I did mine
97 SL2, auto, 123K miles
Old 04-29-2020, 10:57 PM   #5
Hiisi
Hiisi's Avatar
Will buy one, thanks!
Old 04-30-2020, 06:53 AM   #6
onlinebiker
I used an impact once.
It promptly spun the blind nut.
I prefer removing the entire driveline out the bottom over pulling an engine out the top - and I live in the rust belt.
The best tool for the job is PATIENCE.
I use a 1/2 drive socket and breaker bar wirh a 2 foot cheater bar. I break the bolt loose (after multiple PB Blaster soakings) and then work the bolt back and forth alernately loosening and tightening - then I will loosen about 1/16th of a turn at a time - and repeat. Occasional re-applications of penetrant help.
What this does is break off and clears the rust from the bolt. Failure to do this drags the rust into the space between thread faces - and makes the bolt turn progressively harder. Eventually the torque becomes high enough to spin the blind nut.
Taking the extra time actually SAVES time in my experience - saving you from fixing spun blind nuts.
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 04-30-2020, 09:02 AM   #7
Mine came out with PB blaster and a breaker bar. If it gets tight when loosening,. Tighten back up a little more and PB blast it again.
Old 04-30-2020, 09:15 AM   #8
onlinebiker
Next time I drop a drivetrain I plan on replacing the blind nuts with a simple piece of 3/4 inch cold roll steel tapped thru.
That won't spin....
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 04-30-2020, 10:47 AM   #9
Macgyver
The nut retainers always break on me in the salt belt. I'm able to get them off with heat and an impact.
For reassembly, the retaining bracket as it's too far gone so I grind the sides of the circular nut into a 20mm hex bolt. Minimal metal is ground off, takes around 60 seconds to dial in the size with an open ended wrench and bench grinder. I'm then able to get a socket or wrench on it to torque it down to the 150lbs torque spec when aligning the cradle.
Old 04-30-2020, 03:27 PM   #10
Zeebins
Zeebins's Avatar
The clip I broke I used a breaker bar on and the one that didnít I used an impact. It really just depends how bad the clip is before. The broken clip was also on the more rusty transmission side. I used lower control arm bolts putting it back together. M12-1.75 I think.
Old 05-02-2020, 11:19 PM   #11
Hiisi
Hiisi's Avatar
Hey, folks!
Thank you for your great help. This forum rocks!
Luckily I had no issues with the cradle bolts. Came out like a charm! It might be my car is not yet rusty till the degree
The new one is on the car already. I couldn't finish before the sunset but will get Mr. Rusty back on the roads tomorrow.
File Type: jpg IMG_20200502_173632893_HDR_reduced.jpg (212.9 KB, 29 views)
Old 05-03-2020, 01:51 AM   #12
454cid
Originally Posted by Hiisi View Post
Hey, folks!
Wow, cool brick street. We still had brick downtown that was redone that way back in the late 80's or early 90's to duplicate the original brick that had been there. They paved it with asphalt about 10 years ago, Though.
That's a major project to be doing in the street.
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 05-03-2020, 10:05 AM   #13
Nice job!
Old 05-03-2020, 10:49 AM   #14
Zeebins
Zeebins's Avatar
You may already know this but make sure you line up the two guide holes on the front of the subframe with a 3/16 drill bit. (It might be bigger, I donít remember for sure) I forgot when I did mine and had to go back before getting an alignment done.
Old 05-03-2020, 11:53 AM   #15
Hiisi
Hiisi's Avatar
Thank you! I haven't done this yesterday but will check before tightening the bolts.
Old 05-03-2020, 12:51 PM   #16
onlinebiker
That's a new one on me.
I guess I have been lucky. Only one has required realignment.
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 05-03-2020, 01:44 PM   #17
macbox
macbox will become famous soon enough
macbox's Avatar
IIRC, the subframe to spaceframe alignment holes are 9/16", but I used a couple of 1/2" wooden dowels and that has worked fine for a couple of subframes.
#4, "Betty" 1995 SC2m, 167K, rebuilt engine, Garage Queen. Still squeaks and rattles but goes like hell.
macbox is offline   Reply With Quote
Old 05-03-2020, 04:54 PM   #18
dummo
dummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to all
dummo's Avatar
Picture no.3 is an award winner.
It belongs in the 2021 Saturnfans Calendar (with 11 more interesting Saturn images that are yet to be discovered).
Send me your name and address in the private message section and I will send you out a SCCNA weatherproof 4Ē diameter sticker (since it would have won a photo contest).
Hurry, before I show signs of being infected (otherwise cut the envelope shake the sticker out and wash your hands).
ē 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
ē 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
ē 1994 SL1 new traded
ē 1992 SL2 new traded for above
Old 05-09-2020, 11:02 PM   #19
Hiisi
Hiisi's Avatar
Thank you! The sticker is fantastic
Old 05-11-2020, 08:32 AM   #20
Great job - I'm impressed you tackled this on a Pittsburgh street
Will a 2001 DOHC S Series engine cradle/subframe fit my 2002 SL1 with a SOHC engine?? Doug427 S-Series General 3 11-29-2018 12:10 PM
Is this engine cradle gone? tgferg67global S-Series Tech 10 04-11-2011 10:39 PM
Engine cradle harley2003 S-Series General 3 03-15-2010 12:12 AM
Engine cradle frankk S-Series Tech 2 12-08-2008 06:28 PM
sw2 engine cradle augey S-Series Tech 3 03-20-2008 06:27 AM
