Old 05-03-2022, 05:18 PM   #1
theunpaidBill
theunpaidBill has a spectacular aura abouttheunpaidBill has a spectacular aura abouttheunpaidBill has a spectacular aura about
theunpaidBill's Avatar
Default Possible coolant leak?
I checked my oil at lunch and it's clear, but I noticed some dampness along the seam of the head. It doesn't smell like anti-freeze, but honestly my nose isn't great.
I've been looking around the forums and found this post: http://www.saturnfans.com/forums/sho...4&postcount=10
Is this a common issue with the Saturn engines? Should I pop the valve cover and give the head bolts a few more degrees torque? I did the full Oldnuc approved torque process when I put the head on.
Should I just monitor it and see if it's environmental? It's been pretty rainy.
theunpaidBill is offline   Reply With Quote
Old 05-03-2022, 08:51 PM   #2
Default Re: Possible coolant leak?
I would monitor. The low coolant light will go on well before disaster for a small weep.
Old 05-04-2022, 01:08 AM   #3
ultravioletnk
ultravioletnk will become famous soon enough
ultravioletnk's Avatar
2000 SC2
i have read multiple reports of coolant weeping from the seam on the transmission side of the head, however it could also be coming from the coolant temperature sensor or upper radiator hose. did you apply thread sealant to the threads of the temperature sensor when installing it? if not, that would be my prime suspect. if you're confident you got the torque values and final angle correct, i would not tighten the head bolts further.
rings-1996 sl2 ~215k mi
phoebe-1995 sl1 ~250k mi
janus-2000 sohc2 ~190k mi
tethys-1994 sw2 ~302k mi
rip mimas-wrecked 1996 sw1-trailer
pandora-1999 sc2
dione-1998 sw2
penny [iapetus]-1997 sw2
ultravioletnk is offline   Reply With Quote
Old 05-05-2022, 11:09 AM   #4
theunpaidBill
Well I'm pretty sure it's seeping between the head and the block. The edge of the top face of the block I can see behind the exhaust manifold is damp when I check it in the morning. I have seen some damp spots under it, so I think it's worse when it's hot and under pressure. It's not losing much but it's there. I think this weekend I'll pop the valve cover and see if I can get anything on the head bolts without taking the cams out. I figure I don't have a lot to lose if I give them all an extra bit of torque.
Old 05-05-2022, 11:55 AM   #5
With the "torque to yield" design of those screws, you may actually reduce clamping load on the gasket if you fuss with them; may increase the leak (or worse) and cause more serious problems. Either take the head off and do the job right, or leave all as-is.
Old 05-05-2022, 12:16 PM   #6
I would not re-torque them. What's that stuff OldNuc recommended for coolant leaks? Bars leak or something?
The important thing with the head installation is keeping the combustion gasses in the cylinder. Not that we want coolant leaks.
Edit:
http://www.saturnfans.com/forums/sho...13&postcount=4
This was for a coolant leak from the head.
Old 05-05-2022, 02:41 PM   #7
I suppose I should remind us all that aluminum castings are prone to porosity that allows leakage right through the metal; the gasket may not be leaking at all, and no amount of torque on the screws can cure the leak. Those tablets are intended to seal the porosity.
PS: Need I say it? The same applies to oil/fluid leaks from the trans or valve-cover area. Some leaks just have to be tolerated unless you want to get the castings vacuum-impregnated to seal porosity.
Old 05-05-2022, 03:43 PM   #8
theunpaidBill
This is an excellent point, and I was not aware of it. The head got a bath and a valve job so any sealant that might have been in it is long gone.
Why are the tablets preferred over the other stuff? Bar Leak makes a lot of products.
Old 05-05-2022, 04:57 PM   #9
Want a guess? The tablets dissolve to a fluid that can get into the fine porosity and seal by reacting with the aluminum and forming some kind of aluminum oxide/salt in the pores, without risk of plugging larger passages such as in radiator/heater cores. The other products are more fibrous and plug larger leaks by mechanical action, like a beaver's dam; leaks that the tablets can't handle. If it actually is a leaking gasket, then the non-tablet product would probably work better. As a "Hail Mary play", I don't think using both would hurt anything!
Old 05-05-2022, 05:20 PM   #10
My vote is the OldNuc advise. They used the Bars leaks tablets at the factory, if you believe the knowledge he imparted.
Using both seems like a bad idea to me. Go with the minimum - two tablets crushed up and dumped in the reservoir.
Old 05-05-2022, 10:30 PM   #11
theunpaidBill
I picked up the tablets tonight on the way home. I'm going to put them in tomorrow before I drive to work. That should give them a nice long time to get dissolved and do their job.
Old 05-06-2022, 02:26 PM   #12
ultravioletnk
2000 SC2
i think the whole "torque to yield" thing is a bit overblown, all bolts begin to yield at a certain load and i think too much fuss is made about how "different" the tty bolts supposedly are. that said, i agree that once you've done the initial torque sequence, it's not a good idea to go playing with the bolts unless you are removing the head. the initial torque values should provide plenty of clamping force.
i considered suggesting those tablets, but it just rubs me the wrong way to put any kind of particulate/contaminant in the coolant system intentionally. that said, they will probably solve the coolant weeping.
pandora-1999 sc2
dione-1998 sw2
Old 05-12-2022, 04:04 PM   #13
theunpaidBill
2 tablets of Bar's Leak OEM and a week of driving and I'm cautiously optimistic that we have that cured. I checked it when I got gas at lunch and I see no signs of seepage and the coolant tank is full.
Now I have to figure out the P0440 code. It's always something.
Old 05-12-2022, 04:59 PM   #14
TomM96
At my local Saturn dealership, the parts man looked me in the eye
and said ... TWO tabs, at each time you fill the cooling system.
There's a purveyor of diesel engine components in Minnesota, who
uses them in engines with cast iron heads on cast iron blocks.
GM originally developed these for the cast aluminum blocks first deployed on the Cadillac NorthStar engines, then on Saturns, etc.
The last batch I bought has instructions-
"For all automobile cooling systems. * * Use 1 to 1.5 grams of sealant for each quart of coolant system volume."
These newer blisterpacks contents= 5, 4-gram tablets.
ACDelco 10-108 12378255
The coolant mixture should remain full of the particulate --
If it clarifies, that invites leakage.
Old 05-13-2022, 12:37 AM   #15
theunpaidBill
This is the first time I've put some in, but I'm going to remember them.
My P0440 turned out to be easy, the gas cap gasket was crumbling and had more cracks than a nuthouse.
Old 05-13-2022, 11:48 PM   #16
TomM96
> This is the first time I've put some in,....
On my '97, the coolant looked the same always after the initial fill
(and after re-flush & fill when the radiator valve disintegrated).
On my 2000 (got 4 years ago with 166kMi) the coolant has always been weird.
Just recently (began small leak last fall) I figured out what was happening:
The leak filters the coolant, so that a fill begins with lots of suspended
particulates from the coolant seal tabs, but over time, the particulates disappear, and the fluid mix gradually clarifies. So for this engine I may
have to add tablets like medicine, at intervals.
I just got a junkyard head slightly rebuilt; a new head gasket should
improve the situation.
Both my used Saturns needed new gas caps!
Coolant Leak? satz09aura Aura General 15 06-29-2017 12:27 PM
Oil Leak, Coolant Leak, Alternator, Compressor Bobcat124_23456 L-Series Tech 4 03-25-2013 10:13 PM
Coolant Leak! Razzle Dazzle S-Series General 3 05-24-2012 01:06 AM
coolant leak wavejunkie L-Series General 2 11-06-2007 11:28 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 12:56 PM
