Old 11-30-2008, 10:05 AM   #1
tcutt2003vuev6
tcutt2003vuev6 is on a distinguished road
Question 03 v6 AWD Rear Wheel bearing replacement Question
03 v6 AWD Rear Wheel bearing replacement Question....
So where is the How to page for this? I cant seem to find it and everything i saw says its really old topic.. I will also need all torque specs for the Job.
Any help is appreciated!
thanks
todd
tcutt2003vuev6 is offline   Reply With Quote
Old 11-30-2008, 12:43 PM   #2
gmsuv
gmsuv will become famous soon enough
gmsuv's Avatar
2008 VUE 3.6L
Default Re: 03 v6 AWD Rear Wheel bearing replacement Question
Wheel Bearing/Hub Replacement Removal Procedure
Remove the rear brake drum.
On vehicles with all-wheel drive, remove the wheel drive shaft spindle nut.
Disconnect the wheel speed sensor electrical connector, if equipped.
Important
Do not damage the wheel drive shaft joint seal.
Support the wheel drive shaft with heavy mechanic's wire, or equivalent.
Remove the wheel bearing/hub mounting bolts.
Remove the wheel bearing/hub assembly from the suspension knuckle.
Drive Shaft Spindle Nut
Tighten the nut to 125 Nm (92 lb ft).
gmsuv is offline   Reply With Quote
Old 12-01-2008, 12:49 PM   #3
tcutt2003vuev6
Important
Thanks so much!!
I will let you know how it turns out
-todd
Old 12-02-2008, 07:33 PM   #4
1saxman
Can you describe the noise it was making?
Old 12-12-2008, 11:41 AM   #5
mariopalumbo
mariopalumbo is on a distinguished road
2003 VUE 2.2L
I found the wheel bearing hub for $90 (rear, non-abs) at www.autopartswarehouse.com. And after you buy a part they send you coupons for 5,10,15% off your next purchase and free shipping in the US over $50, they claim to have a price match guarantee for all parts sold on-line.
I replaced the rear right bearing last night with the new Timken bearing I bought. The hardest part was removing the rusted brake drum off the assembly. I had to unbolt the bearing hub first and force the drum over the shoes with a pry bar. The bearing hub was rusted solid to the face of the drum and had to beat the crap out of it to come off. In the instructions I found on this site to remove the bearing hub, no-one mentioned that you have to be careful not to damage the e-brake line and brake line attached to brake assembly. When you remove the bearing hub, the brake assembly is unsupported... I had it all done from setup to cleanup in about 2.5 hours. Much quieter now but I am hearing a noise in the front end that was hidden by the screaming rear bearing. Looks like I'm going to order another part....
mariopalumbo is offline   Reply With Quote
Old 08-06-2014, 07:54 PM   #6
QKSILVR73
QKSILVR73 is on a distinguished road
Man wish the pics were still here. Need to do this to mine soon.
QKSILVR73 is offline   Reply With Quote
Rear Wheel Hub/Bearing Replacement uhlemd Vue Tech 23 10-31-2020 03:39 PM
Rear Wheel Bearing Instructions Needed - '04 AWD V6 Vue jjurbanek Vue Tech 8 06-02-2015 10:11 AM
Rear wheel bearing replacement elitemarksman S-Series Tech 6 12-10-2009 10:28 PM
2002 SL Wheel Bearing Replacement Skydmark1 S-Series Tech 19 05-17-2007 08:04 PM
Removing right rear wheel bearing question SLM crew chief S-Series Tech 4 05-17-2004 03:08 AM
