Old 10-14-2020, 01:59 AM   #1
Heidi
Heidi is on a distinguished road
Default Engine swap
I have a 2006 Ion 3 with manual transmission. I'm wanting to know if I can put a 2003 Ion 3 engine with automatic transmission in the 2006 . And what all will I need to change? I'm not swapping the transmissions.
Heidi is offline   Reply With Quote
Old 10-14-2020, 09:58 AM   #2
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
Default Re: Engine swap
Don't have direct knowledge but I think this would be compatible at least in terms of mounting points.
Of course you'll have to change out flywheel, etc.
I'd try and use your existing ECM but not sure if the sensors on the older engine are 100% the same.
Old 10-14-2020, 11:10 AM   #3
ruley73
ruley73's Avatar
Yes, it should work. However, you'll need to reuse the intake and throttlebody off the 2006. The 2006 is throttle-by-wire, but the 2003 still uses a cable throttlebody like most older cars.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 201K miles
2018 Chrysler Pacifica Touring L 63K miles
Old 02-26-2021, 03:10 AM   #4
csalt13
csalt13 is on a distinguished road
I have a 1995 Saturn SL2 with a blown head gasket. I've been looking on ebay and found a few engines from $400-$1000 but most of them are from 1996-1999. Are these engines compatible? Also, what about 1993-1994 engines? They all have a 7 as the 8th digit on the VIN like mine. Does this make a difference?
My saturn has the 1.9L DOHC I4 with a manual transmission 141000 miles.
csalt13 is offline   Reply With Quote
Old 02-27-2021, 03:31 PM   #5
Bill Murray
1997 SC1
You should post this in the S series section, this is the Ion section which uses a different engine.
Old 02-28-2021, 02:01 AM   #6
csalt13
Sorry, I'm still trying to figure out this forum. It's difficult to navigate.
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
engine swap ? 99 sl2 swap in 98sl2 jiffypop S-Series Tech 1 12-11-2010 11:14 AM
Engine Swap or trannie swap SL-2er Miscellaneous Tech 1 04-28-2003 05:00 PM
