Old 07-02-2009, 07:57 PM   #1
chadrules
chadrules is on a distinguished road
Default Transmission fill plug (5spd)
Beside the junk yard and Saturn is there a source for these?
chadrules is offline   Reply With Quote
Old 07-02-2009, 08:05 PM   #2
Squareback
Squareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the rough
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Transmission fill plug (5spd)
There is no transmission fill plug. The transmission is filled through the dipstick. If you're talking about the drain plug, any FLAPS with a good selection of Motormite HELP products should have it.
Certified Saturn Technician
Squareback is offline   Reply With Quote
Old 07-02-2009, 08:10 PM   #3
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
1996 SL2
Correct, you use the drain plug to empty the case then you fill it through the dipstick, so there is no fill plug on these transmissions. Just have to go to a part store and match the pitch and thread. Be careful tightening the drain plug as I was told you can crack the case. I just made mine pretty snug.
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Fox Slaughter is offline   Reply With Quote
Old 07-02-2009, 08:33 PM   #4
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
Also, let me just add that on refill. Make sure that you fill it slowly unless you have a vented funnel (but who does) otherwise there will be a pressure differential and the transmission will belch a whole bunch of fluid back up at you.
Former DD: 1994 SC2 5spd. 190K, being sold to a friend
2005 Saturn ION 2 5spd. 73K
1995 Aquamarine SL2
1.9L DOHC 5spd. ~125K Miles
Col.FUBAR is offline   Reply With Quote
Old 07-03-2009, 02:53 PM   #5
chadrules
This is not an automatic it has a fill plug with a red handle by the shift linkage and it is made of plastic and rubber. I want to replace it because it no longer fits tightly and may let water in the transmission.
Old 07-03-2009, 03:16 PM   #6
Col.FUBAR
Col.FUBAR's Avatar
1994 SC2
Technically that is the dipstick for the transmission, although that is also where you fill it up at so it could also be called the fill plug I suppose.
1995 Aquamarine SL2
Old 07-03-2009, 03:34 PM   #7
chadrules
Well i'll be damned! so one of my cars has a dipstick and the other doesn't, explains why it doesnt stay put so well now. I was very careful measuring the ammount of fluid I put in because I thought it was prety stupid to not have a dipstick.
I still need a replacement.
1996 SC1 (bought for $120) 185,000 miles
1997 SW1 - 201,500 miles
1994 SW2 - 250,000(?) miles (SOLD)
Old 07-03-2009, 05:52 PM   #8
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Pretty sure you'll have to get it from a dealer (or saturnparts.net, which is a dealer that sells parts online), or from a junkyard. I highly doubt there is an aftermarket version.
SaturnSeries.net owner
Old 07-03-2009, 06:14 PM   #9
Get from a Junk Yard. The dealer is expensive.
Old 07-03-2009, 06:37 PM   #10
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
And we all know that the red handle of the dipstick folds down to tighten it and keep it from coming out? Unlike a regular dipstick, when you fold the red handle down it pulls up the washer on the end, squishing the rubber portion, increasing its diameter and sealing red stuff inside.
MiSaturn is offline   Reply With Quote
Old 07-03-2009, 09:10 PM   #11
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
Mine's loose too like the OP describes.. It needs to be replaced.. Been meaning to find a good one at the JY. all the donor cars I've been visiting (2 leather, ABS, rear disc SL2's) are automatic trans.. no dipstick for me
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
SLCraig is offline   Reply With Quote
Old 07-03-2009, 09:48 PM   #12
Take a regular 5/16 0r 3/8 flat washer, I forget which one fits, and cut a radial slot to the center. Slip the washer between the cam handle and the top and rotate it so the cam handle does not rotate it off the stem. Now its tight again. Much cheaper than any replacement.
Old 07-03-2009, 11:08 PM   #13
MikeNW
MikeNW's Avatar
1997 SL
Old Nuc beat me to it.
The washer trick works well.
(I am cheap, owned a Kawasaki Concours C10 for a while. Now that website is full of frugal people!)
08 Burgman 400
2003 Ion 1 AF23 5spd Transmission jkenley Ion General 2 10-06-2010 07:15 PM
standard transmission fluid top up/fill Mike88 L-Series Tech 1 05-12-2008 06:11 PM
standard trans check/fill plug Jeff K S-Series General 8 03-01-2006 10:48 PM
WTB: 5spd Transmission Madson26 Classifieds 7 08-10-2005 08:40 AM
