Old 10-28-2004, 06:37 PM   #1
auger
auger is on a distinguished road
Question EVO/Non-EVO Steering pump differences
Can anyone tell me what the difference is between a pump with EVO and one without? Is it that the reservoir only, the fact that the EVO equipped pumps have a reservoir that accepts the EVO unit and the non-EVO pumps don't?
Reason I ask is, I have a '99 non-EVO pump I got from a wreckers, and my '92 leaky-noisey pump is EVO, if I could swap reservoirs on these would that be the way to go with this?
auger is offline
Old 10-28-2004, 09:49 PM   #2
wolfman
wolfman's Avatar
Default
Basically none. An EVO pump installed in a non-EVO car with it's EVO connector left disconnected will simply be on full boost (assist) all the time. IF however you install a non EVO equiped pump on a car that has the wiring for an EVO equiped pump, meaning there is nothing to plug the EVO connector to, the pump will still deliver full assist all time....and an SES light ...all the time.
wolfman is offline
Old 10-28-2004, 10:07 PM   #3
LATEMODELRACING
LATEMODELRACING is on a distinguished road
Default
besides that darn light
LATEMODELRACING is offline
Old 10-29-2004, 12:01 AM   #4
Default
Are you sure that your 92 SL1 has the EVO on the PS? As far as I know it was availible on the DOHC engines only not the SOHC ones. If there is an electrical connector to the PS pump then it does have EVO. No electrical connector then no EVO.
ssicarman is offline
Old 10-29-2004, 01:17 PM   #5
auger
Default
Thanks guys, Ssicarman, mine has the electrical connection, apparantly Saturn stopped offering EVO on SL1s around '95 or so and it became something the more expensive models got.
I have found a rebuilt for $237 with EVO, I think I'm gonna bight the bullet and buy it, my car is still running very well and uses about a half quart of oil between services.
Thanks again for the excellent advise.
auger is offline
Old 10-29-2004, 01:46 PM   #6
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default
what does EVO stand for?
Electrical Valve Operation??? I'm just guessing...
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline
Old 10-29-2004, 03:08 PM   #7
auger
Default
Electronic Variable Orifice, according to my Chiltons......
auger is offline
Power steering pump - EVO or not? mr18436572 S-Series Tech 25 04-15-2016 05:24 PM
Need power steering pump EVO swapover help! 93goldsl2 S-Series Tech 2 10-11-2011 06:41 PM
Help Install EVO on Power Steering Pump alrich S-Series Tech 7 10-11-2011 06:15 PM
Power steering pump leak at EVO - diagram needed gkainz S-Series Tech 1 08-22-2008 09:09 AM
Steering - EVO wiring? gkainz S-Series Tech 2 12-11-2006 07:09 PM
