Old 03-10-2009, 01:43 PM   #1
toddmog
toddmog is on a distinguished road
Default ATF Change Question
I looked in the How-To Library and have found different responses in the same thread. They are quoted below:
Originally Posted by wolfman View Post
You will need:
A drain pan capable of holding 2 GALLONS (8 quarts) of liquid
Set of metric wrenches
Oil GOOD filter wrench
RAGS
7 quarts of clean ATF (Mobil 1 synthetic ATF HIGHLY recommended)
Replacement transaxle filter (Buy it from SATURN, not the autoparts store)
Originally Posted by Growser View Post
Get to the AT filter by removing the airbox for easier access. Have a Saturn OEM AT filter ready and 4.2 Quarts of Dexron III or IV (check your owner's manual) for fluid capacities.
I'm going to change the fluid soon and want to make sure I purchase enough ATF, but don't want to over-purchase either. So how much should I buy?
Also, would I be okay using a Wix filter from O'Reilly's? My closest Saturn dealerships are 35 and 40 miles away.
1998 SL2...Completely Stock...Automatic...Power Everything...133K
toddmog is offline   Reply With Quote
Old 03-10-2009, 01:53 PM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: ATF Change Question
WIX filter will be fine, you need 5 quarts of fluid, you will only use about 4.5.
Certified Saturn Technician
Old 03-10-2009, 02:19 PM   #3
toddmog
Great...Thanks!
Old 03-10-2009, 02:49 PM   #4
Kaervak
Kaervak has a spectacular aura aboutKaervak has a spectacular aura about
Kaervak's Avatar
Check your local Wal-Mart for Mobil 1 synthetic ATF. I got pretty lucky and picked up five quarts for $20 + tax last night in their clearance section. I know it's not a guarantee that yours will have it, but can't hurt to check.
Kaervak is offline   Reply With Quote
Old 03-10-2009, 02:54 PM   #5
toddmog
Nice find! If I can get it for that price, I'll likely empty the shelf.
93 SC2 ATF Change PuNkY S-Series General 12 07-01-2009 09:27 PM
ATF Change with Fluid Extractor coupster S-Series Tech 4 12-28-2008 11:50 PM
Should i change synthetic ATF? mr18436572 S-Series General 2 12-22-2007 09:27 PM
TB cleaning, ATF change, and a question. Vue&SL1 S-Series Tech 6 12-19-2007 10:59 PM
ATF Change and Reverse Slam Norseman S-Series Tech 4 10-02-2006 08:55 PM
