Old 08-17-2022, 03:50 PM   #1
Highmile
Highmile's Avatar
Default Failed Wheel Bearing and more
SO replaced both front wheel bearings about 20k as part of the 750k maintenance I did. I've always used Timken bearings and used them again this time.
I've replaced a number of them over the years and miles not only on my car but others as well. Every single bearing was a ball bearing with a split inner race. This bearing however was a roller bearing. The inner race had locked up and was now spinning on the hub. The one thing that really struck me was the total lack of grease inside the bearing.
So I took the new bearing and slid the inner races out and guess what, ball bearings and a near lack of grease. The lack of grease is an easy fix.
Now I'm just wondering how long before the other side fails.
Highmile
'95 SL1 760k and counting
Old 08-18-2022, 12:54 PM   #2
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Default Re: Failed Wheel Bearing and more
I put a Timken made in china in my 02 passenger side about 20k miles ago....I'm still expecting it to fail.
I couldn't find any bearing that were not china. The SKF I put in the drivers this weekend said to see the catalog for point of origin......
Old 08-18-2022, 01:32 PM   #3
billr
The last Timken I installed, a "SET39" tapered-roller, was engraved "Made in USA"
Old 08-19-2022, 05:31 AM   #4
1996SL11.9L
2002 SL1
I’ll admit I bought the Timkin on Amazon…..
Old 08-21-2022, 08:41 AM   #5
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by Highmile View Post
...The lack of grease is an easy fix...
Highmile
Do you have a recommendation on what grease everyone should use?
It sounds like adding grease should be routine...
Old 08-21-2022, 09:42 AM   #6
Macgyver
Timken is turning into garbage, at least when it comes to their bearings. Due to the labor involved with pressing them in the knuckle, it’s worth the time to get OEM. They’re currently made in Canada – part number 18018861
Old 08-22-2022, 09:17 AM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
Thanks, if you hadn’t told us, we would never know. You’d think “Made in Canada” would be a selling point!
Nothing mentions Canada.
Item weight: 1 pounds
...Due to the labor involved with pressing them in the knuckle..
Man, do I agree with that!
Old 08-22-2022, 03:47 PM   #8
hholbein
hholbein is just really nicehholbein is just really nicehholbein is just really nicehholbein is just really nice
1997 SW2
I've had much better luck with the consistent quality of SKF bearings.
Timken not so much since the company split/corporate games/exec payouts gone wild several years back.
https://news.timken.com/2013-09-05-T...ded-Companies#
Old 08-23-2022, 05:26 PM   #9
1996SL11.9L
2002 SL1
An SKF is in the drivers side. Sadly the boxes said to look in the catalog for point of origin. I’m guessing China.
Bad Front Axle Bearing (Not wheel bearing) ? cjhsa Vue General 19 08-08-2017 08:56 PM
Front wheel bearings failed again. SLCraig S-Series Tech 27 10-30-2015 11:45 AM
A/C problem: Cools great, sounds like failed bearing Tangent Vue Tech 4 10-27-2010 06:37 PM
Wheel bearing noise that isn't the wheel bearing? shelby987 Vue Tech 0 06-23-2010 11:16 PM
ABS wheel speed sensor failed silvervoo Vue General 3 08-18-2004 01:37 PM
