Old 08-13-2022, 02:36 PM   #1
spacetrace33
spacetrace33 is on a distinguished road
spacetrace33's Avatar
2000 SL1
Default Manual Trans shifter cable woes
2000 sl2.
Last night, my car got stuck in 2nd gear due to a shifter cable end.
On transmission side, the lowest cable, inside the eyelet, lost its bushing, or inards. Ended up loosing the small clip during the proces, which isn't a huge deal.
But what is a deal for me, is making a repair to this eyelet. I found the inards on the ground, and it looks pretty worn out, so it probably won't hold. Haven't tried it yet.
Has anybody successfully repaired this issue, without replacing the cable? If so, could you direct me to the nearest write up, or share your expertise?
00 SL1 Daily Driver Frankenstein
98 SL2 race car-not street legal by any means
01 SC2 race car-not street legal by any means
00 SL2 aka boom boom pow
spacetrace33 is offline   Reply With Quote
Old 08-13-2022, 03:43 PM   #2
Default Re: Manual Trans shifter cable woes
You mean like this?
Then you need this:
https://www.ebay.com/itm/124833995949
Easy repair.
Old 08-13-2022, 03:56 PM   #3
I think the OP is asking about the bushing on the other end of the cable, at the trans.
Yes, the bushing at the trans end seems to be easier to replace, as it doesn't have to swivel in two directions. I think somebody even used just a plain nut, with washers on either side, for a while to "bush" the hole. Maybe just a piece of rubber hose and washers, used similarly???
Old 08-13-2022, 04:38 PM   #4
spacetrace33
2000 SL1
Precisely, Trans side.
That's an idea you got there. Might end up trying it. Really want factory style though.
Old 08-22-2022, 03:39 PM   #5
hholbein
hholbein is just really nicehholbein is just really nicehholbein is just really nicehholbein is just really nice
Check out midway through this post where someone had success replacing the cable ends with Heim joints:
https://forum.sixthsphere.com/forum/...cable-ends-fix
Ball joint setup with McMaster 6072K31 on the trans and 6072K154 on the shifter
Old 08-23-2022, 01:59 PM   #6
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
1996 SC2
Just get the vest set you can find at pick n pull. The transmission side rarely fails so you can probably find some good ones.
The rod end replacement approach would be the most durable but very time consuming and require a lot of rigging to get right.
Old 08-24-2022, 04:57 PM   #7
Melissa_M
Melissa_M is a jewel in the roughMelissa_M is a jewel in the roughMelissa_M is a jewel in the rough
Melissa_M's Avatar
what are you going to do about the clip?
I also have manual, so I have read a LOT of threads over the years. There are a very few mentions of DIY replacements for that bushing at the transmission, but I cannot remember the specifics. It was not a specific part (like the dorman wiper bushing that you use at the other end), otherwise I would have put it into my notes.
1999 SL2 MANUAL ~79K
Melissa_M is offline   Reply With Quote
2002 SC2 manual shifter woes Lightfoot2002 S-Series General 8 01-01-2017 07:06 PM
sl2 auto trans shifter cable R&R at trans how to operator john S-Series Tech 1 10-28-2014 06:33 PM
Clip for shifter cable on manual trans gearhead S-Series Tech 2 01-03-2011 01:07 PM
Shifter Cable, Trans end Highmile S-Series Tech 2 10-17-2009 10:43 PM
Automatic Trans shifter cable MacExperts S-Series General 2 05-23-2009 07:53 PM
