Old 05-19-2022, 06:25 PM   #1
daytona701
daytona701 is on a distinguished road
2009 VUE 2.4L
Default 2009 Vue 2.4 ac fan
Amateur here, Iím trying to help a family member. Got a engine overheat/ac off on dash. Engine was running fine so changed coolant sensor and cleared dtc. Air conditioner came on after a couple of minutes and everything seemed good. Now compressor engages but fan doesnít seem to come on. Checked voltage at fan plug and got 13.4 volts on high setting. Bench tested fan with 12.4 car battery and it spun fine. Reinstalled and fan wonít work with 13.4 at the plug. Canít figure this one out. Would appreciate advice on what to look for. Thanks.
daytona701 is offline   Reply With Quote
Old 05-19-2022, 11:00 PM   #2
Default Re: 2009 Vue 2.4 ac fan
Fan ground may be the problem. While you found 12v on one wire, try tracing the ground wire or a continuity test (measuring for resistance on the ground terminal to chassis).
Old 05-27-2022, 12:50 AM   #3
RedCrayola
RedCrayola is on a distinguished road
Also worth checking the resister in the wheel well for continuity.
https://www.saturnfans.com/forums/sh...d.php?t=159303
RedCrayola is offline   Reply With Quote
Tags
blower fan
2009 Sky between5and7 Introductions & Greetings 1 08-14-2019 07:03 PM
2009 vue MMarlin Vue General 10 10-27-2009 10:19 PM
2009 Vue ??? jgibson146 2008 Vue 3 07-26-2008 12:30 AM
Changes for 2009 djreed Aura General 76 04-11-2008 01:56 AM
Changes for 2009.... Dirxque2 Outlook General 3 12-20-2007 08:04 PM
