#1 |
![]() Join Date: Apr 2022
2005 saturn vue 2.2 manual.
Just swapped out my engine, I believe I have everything hooked up correctly. Currently engine doesnt turn over, I can hear the starter click , but doesnt attempt to turn over engine. Has new battery. I feel I may have some ground wires in wrong place, how many wires go to starter? Anyone have photos ? Or advice of where to begin diagnosis. Any help would be greatly appreciated |
#2 |
Thinking maybe a computer issue? No spark, no fuel,I tried hooking up an ob2 scanner , and say unable to link
#3 |
there should be a smaller wire that activates the solenoid (on s-series it's purple, i'm not sure about vues) and a much larger wire directly from the battery. if you only connected the smaller wire, you would probably get a starter click but no cranking.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
#4 |
After alot of looking around I found a ground wire not hooked up🤷*♂️ current situation is, it turns over but no fuel or spark, also ob2 scanner stil wont link. for a break down the replacement motor is a boneyard motor. They said it was from same vehicle. But as I went along the way ,had to swap out a few things (fuel rail, engine mount, flywheel, *pretty sure engine came out of an automatic instead of manual * I do have service engine light on, any tip or tricks to get me started?
#5 |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2016
2003 VUE 2.2L
Do you have the correct ECM for the manual transmission??
Is the ECM grounded. There is a ground wire under one of the ECM bolts. Crankshaft sensor, I believe its located under the starter.
2003 Vue - 2.2L with Manual Trans. (Swapped) Originally had 2.2L and Auto trans. |
Bookmarks |
Tags |
#engineswap#help |
Saturn vue engine swap | Max Somerville | Vue General | 7 | 04-13-2019 10:35 AM |
Saturn engine swap | BigPaul | Ion Mods | 3 | 12-16-2017 01:25 PM |
95 Saturn SL1 engine swap? | bob95saturn | S-Series General | 16 | 07-26-2006 03:13 PM |
I need help with 93/97 saturn engine swap | jason020579 | S-Series General | 8 | 08-04-2005 01:56 PM |
saturn engine swap | n1571 | S-Series General | 1 | 10-28-2004 01:10 PM |
