#1 |
![]() Join Date: Feb 2022
Trying to help a friend with his 2002 LW 300
I just did his timing belt and water pump but he now has an overheating issue Thermostat is opening, fans are kicking on, upper and lower hoses are hot but radiator is cold as is the air being blown out from the fans I'm leaning towards a clog in the radiator but anything I might be missing in this assessment pointed out to me would be helpful. (3.0 V6) |
#2 |
Are you sure the cooling system was refilled, engine started, allowed to idle as air remaining in the cooling system self purged with or without the coolant container cap on? On level ground, the cooling system will self purge any air in the system into the coolant container. A brief drive around the block will do the same. Then top off. Saturns do not have heater core shut off valves. Coolant always flows for immediate heating as the engine warms up, regardless of t-stat operation. Approximately 7 qts needed.
#3 |
Yes. Put in almost 2 gallons. Even if it was a little low the radiator should still get at least warm to the touch.
#4 |
How do you know the t-stat is opening? Temperature gauge needle moving from cold to ...? Can you connect a reader/scantool to monitor coolant temperatures from startup to overheating? It's rare for t-stats to stick closed when most open sooner, resulting in cooler running. Sometimes an error code points to the engine temperature being lower. L300s should be running 195F.
#5 |
Don't have a scanner with that capability. Needle goes from cold to over 3/4 mark with fans kicking on just below 1/2 way point.
Radiator fill bottle fills up completely when t-stat opens so I know that is working which happens when about time fans kick on. |
#6 |
![]() ![]() ![]() ![]() Join Date: Jan 2018
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Possibly an issue with the water pump, or the installation
2002 L300 Sedan 2003 LW300 Wagon 2005 L300 Sedan |
Bookmarks |
Overheating, where is the radiator cap? | sushikam | Ion Tech | 1 | 09-21-2011 09:04 PM |
Car overheating after disassembling the radiator | jihnsius | S-Series General | 23 | 04-08-2011 07:46 PM |
95 sl1 overheating after radiator change | losttxn4evr | S-Series General | 21 | 05-28-2009 11:54 PM |
Radiator petcock and overheating SC2 | peppermrj | S-Series Tech | 4 | 07-24-2005 10:13 AM |
Overheating fixed - Radiator Questions | usa4624 | L-Series General | 2 | 07-09-2005 09:30 PM |
