Old 12-06-2021, 01:01 AM   #1
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default Power Steering Seal
Anyone have experience replacing the power steering shaft seal on the V-6 pump ?
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
lrbraner is offline   Reply With Quote
Old 12-06-2021, 09:51 PM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: Power Steering Seal
Well if it is like every other power steering pump that I have resealed. Remove the pulley( special tool ), disassemble pump, replace seals, assemble pump and install pulley( different special tool). 😀
2002 L200/5 Loaded, over 1/4 million miles!
Old 12-08-2021, 04:55 PM   #3
lrbraner
I was hoping for a little more specific information.
The shaft seal is the only thing that needs replaced.
Was hoping to do it in the car. Without removing the pump.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 12-12-2021, 03:46 PM   #4
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
Considering the age if you haven't replaced or redid the PS itself then replacing is a better value for the age of the car. The amount of reconditioning you'll be doing would far exceed replacing the PS pump. And doing that would get you warranty should it fail during it warranty period.
Old 12-13-2021, 03:16 AM   #5
pierrot
pierrot's Avatar
The shaft seal is the only that needs replaced.
FWIW, while I was in the automotive business and knew of mechanics who did such jobs they never replaced a p/st pump shaft seal while the pump remained mounted to the engine. I doubt that there's adequate space available under the hood of an L-Series car to use the tools required for performing this repair. The primary problem relates to the removal of the pulley. The length of tool and its operation makes an on car repair impossible, or minimally, implausible. Additionally, one may damage the bracketing during the course of such work. But who knows? Maybe I'm wrong and this job can be done "on the car." (Let the DIYer beware...)
374K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct...too bad... now Russia?!
Power Steering Pump Seal Replacement ROCCERO4 S-Series General 1 05-27-2013 08:40 PM
Power steering pump seal replacement unr.grad S-Series Tech 2 10-13-2008 04:01 PM
How do I Replace Power Steering Pump Seal? Old Crow S-Series Tech 0 10-06-2006 06:13 PM
power steering pump seal kmix99 S-Series General 6 02-08-2005 12:05 PM
Power Steering Pump Seal DaveL167 S-Series Tech 8 12-09-2003 01:26 AM
