Old 08-09-2021, 01:33 PM   #1
Banksy
Banksy is a jewel in the roughBanksy is a jewel in the roughBanksy is a jewel in the rough
Default How reliable are the 05 Vues?
I have one im interested in locally
Ive had 3 S series, but never a VUE
my sister had the 4 banger Vue and loved it. lasted well like 200k
This one locally has the V6 in it which from what i understand is a honda engine mashed with a honda transmission as well.
What are some of the main issues i should be looking for? This Vue in question has 213k on it with a fresh PA inspection.
What are the BIGGEST issues on these cars?
Banksy is offline   Reply With Quote
Old 08-09-2021, 01:38 PM   #2
waiter21
2003 VUE 2.2L
Default Re: How reliable are the 05 Vues?
I's say once you get past the 2004s, rust will be the number one killer.
Front engine cradle mounts, rear suspension mounts, fuel lines.
Old 08-09-2021, 05:24 PM   #3
Cavell
Agree. 16 yr old PA vue? Rust.
How old is timing belt?
Old 08-09-2021, 08:44 PM   #4
Banksy
Waiting to hear back from owner. This is my biggest concern
Old 08-09-2021, 10:12 PM   #5
waiter21
2003 VUE 2.2L
This is how I repaired mine:
https://www.1999southwind.com/toad-2...#ENGINE_CRADLE
Old 08-10-2021, 09:36 AM   #6
Cavell
Has plastic body. It always looks good. Till you look under it.
Get one from Texas. Haha.
Old 08-10-2021, 10:44 AM   #7
waiter21
2003 VUE 2.2L
Thats where I got my engine cradle from, Texas. Mine was rusted in half.
http://www.saturnfans.com/forums/sho...d.php?t=234668
Old 08-11-2021, 02:18 PM   #8
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
Original owner, only maintenance. Zero issues, recently power door locks went wonky, replace L and R and OK now. Corrosion between soldered connection inside of Right switch. With 45 years of driving best reliable vehicle. 106k miles. Seats are horrible during long trips. No rust down here in SC.
JefferyC is offline   Reply With Quote
Old 08-13-2021, 08:33 PM   #9
atikovi
Besides the frame rust mentioned, over 200K the transmission is the big ticket item to worry about. Could easily go another 100K or could go out in 10K. Usually not worth rebuilding at that point but if you can DIY, a junkyard transmission is a good option. Rear diff is probably worn out with those miles but unless you NEED 4x4, not a big problem. A/C control valves on the compressor often go bad and there is a cheap fix if you DIY, but most shops will only replace the whole compressor.
Vue reliable walt Vue General 8 09-29-2013 01:09 AM
I am looking for a reliable vechile. darklide Vue General 2 11-27-2009 06:33 PM
Very Reliable MPR2001GTi Vue General 0 08-04-2005 01:40 PM
How reliable? OPEC General Saturn Discussion 3 02-27-2002 10:12 AM
