![]() Join Date: Jul 2019
2002 SL2 with 150k miles. Recent work history includes a replacement of front 02 sensor and a cleaning of the EGR valve, both prompted by check engine lights that have not returned since the work was done. New starter about a year ago. No other current codes pending or logged in the computer.
EGR valve cleaning was done about ten days ago. Last week as I go back to my car after about minutes to run my kiddo into day camp, car tries to start but can't. Turn key all the way off, try to start again, bam, off and running. This has happened three times since. Every time when she has been sitting for less than 5 minutes or so. She has started easily when trying to start her back to back AND has started a couple times even when sitting less than 5 minutes. So far she has not failed to start if sitting longer. I've read a million posts about everything from CPS to ECTS to fuel pump relays and so on. Just caught another post that it could still be the EGR, just not throwing a code. Read a couple folks claim bad gas could do this... ( I just put some way better gas in the tank but that was a day or so ago) So I took a video. Had my family wondering why I kept recording starting the car but maybe it will pay off. Hoping folks can take a look and let me know what they think. I broke up the url as apparently I haven't made enough posts yet... h t t p s://youtu. be/1cV9My9SeM4 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
https://youtu.be/1cV9My9SeM4
I don't think that is an EGR problem. Sounds like a weak crank due to lack of juice to me. I'd check the battery connections before I did anything. This includes both side posts, ground connection to block and chassis, power connection to starter and under hood junction box. After that I'd look at the battery.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
So looked at connections, tightened the battery positive as it had a very small amount of tension it could take.
I'll take the battery in and have it scanned but it is only six months old. Does it make sense that a bad connection or battery would lead to this issue only occasionally?
Gileddb "Rainbow Rose" 2002 SL2 150k miles |
#4 | |
#5 |
I'm guessing that you need a new fuel pressure regulator. If you can consistently start your car by turning your key to the Run position just before Ignition, waiting for the fuel pump buzzing sound to stop, and then turning the key to ignition, then you have a leaking check valve in the fuel pressure regulator that slowly bleeds out pressure overnight.
#6 | |
#7 | |
#8 | |
https://www.dbelectrical.com/product...02-saturn.html
#9 |
If the problem is intermittent, then it can be hard to diagnose, unless you can consistently start your car as I described.
#10 |
![]() ![]() ![]() Join Date: Mar 2015
1997 SC2
1999 SC2
Most likely its your CPS. Cheap and easy sensor to replace. Mine goes bad every few years with very similar symptoms. Letting the car sit and cool almost always allows a successful start. Just get one that has a lifetime replacement warranty.
In the hot weather, it's more likely to fail due to thermal expansion of the internal electrical connections. It's a very common failure. |
#11 | |
Regardless if the CPS is the culprit my understanding is I pretty much have to: A. Get her off the ground. B. Take of the starter. I could do B I guess, if I had resources to do A...but I don't have good access to flat land or jack stands and I have heard taking off the starter is a chore. I see richpin has a video to test that the CPS is functioning. Is it possible for a CPS to pass his test but till cause the trouble described?
#12 |
![]() ![]() ![]() ![]() Join Date: Nov 2018
2001 SL
I have very similar problems currently. Except for my issue it has issues starting up when I let it sit for awhile. I have a new fuel pump and filter coming in since I JUST replaced the faulty starter that I thought was the problem (still needed replacing anyways!) and had no luck with the intermittent no start issue. Since everything on this car I've replaced has been pretty much OEM I have no doubt that the fuel pump and filter are 18 years old. I'll let you know how it goes.
#13 |
Jack stands:
https://www.harborfreight.com/3-ton-...nds-61196.html Walmart has them too. Or find a friend with them.
#14 | |||
When it fails to start, it cranks normally, just does not "catch" and start/run?
I would check the positive cable in the middle - you sometimes get corrosion in the middle even though the ends look clean. Grab the cable in a couple spots in the middle, bend /flex it slightly. If it feels "crunchy", replace or clean with baking soda solution. I don't think this is your problem if the cranking sounds normal and you have good spark, but it costs $0 to check. Quote:
I suppose it is possible in your normal driving that your car gets just hot enough to cause the CPS to temporarily fail after sitting a few minutes (heat soak), but then within a few more minutes, cool off enough to start. And it doesn't get hot enough to fail and stall while driving that distance. It would be a weird coincidence, but stranger things have happened. ![]() Quote:
Taking the starter off is simple, two bolts and you are done. Putting it back on is hard because you are trying to put the top bolt into its hole blindly and using a socket with extension to hold the bolt. Richpin's starter video shows him using a mirror to locate the top bolt hole, but I've never been able to see it. I used a piece of duct tape to hold the bolt into the socket (it kept falling out while trying to put it into the hole) Quote:
This will help with the CPS location http://www.saturnfans.com/photos/sho...ations/cat/500 (CPS callout is at lower left of diagram) http://www.saturnfans.com/photos/sho...ensors/cat/500
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#15 | |
It’s pretty straight forward to diagnose a fuel pump vs a starter. -Robert |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010
"If it feels "crunchy", replace or clean with baking soda solution". This cleaning would only apply to the visible ends and no where else.
Since that positive cable has an intact PVC jacket, if it were crunchy, there is no way to ever clean that middle with anything, unless y'all were to slice it open (not recommended). Just replace that cable with a new one. ![]() |
#17 |
Yes yes, I know where to buy them. I'm the most car oriented of my friends so no extended network of friends with tools, I am the friend.
My main issue is flat land. A buddy just offered his driveway. If this seems like the culprit I know how to throw money at the problem. Just want to be on the right track.
#18 | |
I know where the CPS is but I'll admit I am daunted and without knowing for sure its the issue as it is more akin to throwing down for some jack stands and the parts AND getting underneath a car for the first time. Not just badda bing, in and done. I don't have that confidence yet. Hey, first time for everything. I'll double check the cable and report back when I know more.
#19 | |
Cables are in good shape. Honestly for all her chipped paint and torn up interior my engine compartment is in great shape. I think a fair amount of her cables and stuff were either replaced, restored or were actually well cared for before I got her. No hiccups on starts at all today after tightening that positive terminal. I guess I now just need to let some more time pass and see what comes. Thanks everyone for the ideas. To be continued?
#20 |
No worries!
1998 SL1 intermittent starting issue? | bk2futr | S-Series Tech | 5 | 09-22-2014 05:14 PM |
2002 L300 -- Intermittent Starting Issue | jessdykstra | L-Series Tech | 4 | 07-27-2013 02:34 PM |
2002 SL1 intermittent starting issue question | sarahlynne | S-Series Tech | 1 | 08-24-2012 07:43 PM |
1998 SL2 intermittent starting issue | scottb022563 | S-Series Tech | 6 | 02-03-2009 01:24 PM |
intermittent starting 98 sc2 | Buefordtjustice | S-Series General | 13 | 12-10-2006 03:07 PM |
