#1 |
![]() Join Date: Mar 2012
1998 SL1
I'm freaking sick of her. This year I've had to replace my battery, battery cables, starter, alternator, and ECTS. AND she is still not turning over/ starting. Could it be the CPS or the fuel pump? I'm a college student/delivery driver and I cannot deal with an unreliable car anymore. If you have any ideas post em. I'll be very appreciative.
#2 |
![]() ![]() ![]() Join Date: Feb 2012
How's the fuel pressure? Fuel filter been replaced?
Current: 1999 SC2, 198,XXX Past: 1989 Mustang LX, Unknown mileage(JY engine in it when I got it) |
#3 |
"Not turning over" - so when it doesn't start, you mean it doesn't do anything when you turn the key? Do you hear a click anywhere, under the dash or under the hood? Automatic or manual transmission?
BTW, your member name consists of the names of two Detroit high schools.... |
#4 |
1998 SL1
the solenoid is definitely engaging, but that baby won't turn over!
#5 |
1998 SL1
She will turn on, lights come on and so does the radio. The engine however will not turn over and lemme back out of the freaking parking lot. I turn the key in the ignition to start it, but the solenoid just keeps clicking.
#6 |
If it's not turning over (spinning the engine) then it can't be anything outside of a battery, cable or starter problem unless the engine is seized. Easiest to try fixing is corroded battery cables, both on the battery ends and on the body/not-battery ends.
#7 |
1998 SL1
I didn't replace my positive battery cable... I looked inside the battery part to see if it was corroded and it wasn't. That starter is brand new too. How do I tell if the engine is seized? The battery has been tested like every week too.
#8 |
![]() Join Date: Oct 2012
Take a test light, and see if you're getting power to your solenoid on the starter. If you are, tap the solenoid/starter and then try to start. There is a chance your starter could be bad. If you hear a clicking noise on the starter, don't go chasing parts. Find out why.
96 SC2 - 137k - AUTO. 94 SL2 - 200k? + 2nd owner AUTO |
#9 |
Before going for test equipment do this, turn on headlights before attempting to start car and be sure you can see the reflection of the lights in something or get an observer. Now crank engine and watch the lights, do they get dim or go out? If the starter actually cranks the engine that is not what you are looking for you want to be checking the headlights when it does not crank but the solenoid clicks. This could be a bad positive or ground cable but it is 1 or the other or both as long as the starter is good.
#10 |
1998 SL1
Yeah checked the lights it seems like there is still bad ground issues. I guess I should've replaced my positive cable when I did my negative the other day. Is there any other cable aside from that one that can affect my saturn. I know part of it runs to the starter which is where it must've gone bad? This is irritating.
#11 |
![]() Join Date: Jun 2009
ive had a fuel pump go on me in an sl2 not fun tried to fix myself bad idea, had to pay a mechanic to re do it it ran for like a day then broke again wouldnt start
#12 |
1998 SL1
The lights dim* which is a sign of bad ground right?
#13 |
the lights dimming, but the engine not cranking is a sign of weak battery or dirty connectons. If you're sure that those things are operating correctly, suspect a fuel delivery problem. Before you start the car, turn the key to run, and listen for the fuel pump. It should be a slight humming sound, you'll need to be in a garage or quiet street to be sure.
Cables and wires almost never fail; the terminations do. -- www.prussianmotors.com |
#14 |
![]() ![]() ![]() ![]() Join Date: May 2008
2004 VUE 2.2L
You're indicating the lights dim but the starter will not make the engine rotate is this correct? This MIGHT be a bad/faulty/dirty connection, a bad battery (especially if you're getting a clicking), and if you're not cautious about oil level who knows a seized engine. As for people sending you down the path of fuel I don't know why. This will have nothing to do with the starter's inability to rotate the engine. Now IF the engine IS rotating and not STARTING than you could need to chase down fuel or ignition issues. The issue here (especially so on this thread) is people post the words "crank", and "turn over" in wrong context.
An engine that is "cranking" or "turning over" means the starter motor when energized is causing the engine to rotate. So OP you may need to correct your actual description of this issue. |
#15 |
![]() ![]() ![]() Join Date: Apr 2009
...is this happening with the temp gauge at least at the 1/4 line or higher? if so, suspect fouled starter and a replacement is imminent.
97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat |
#16 | |
![]() Quote:
Keep in mind that new starters have been known to be defective as well so you may have 2 problems but you are not going to find out until the positive cable is replaced. This problem is almost always the positive cable and not the ground cable. |
#17 |
To see if the engine is siedes, follow this easy step:
Check the oil. BTW, If your car wont crnk, it could be the fuel filter. Mine had the same problem, and that was it. |
#18 |
1998 SL1
It seems like it is happening all the time, but I will say that I need a jump in order to get her whenever the temp is 1/4 or higher. Usually whenever it's an absolute cold start it will take a couple seconds to start, but it does. I guess the best thing to do is to get another positive cable first then I'll have to check the starter. Glad I got the warranty on that...
#19 |
First, replace the positive cable. Why? Because the starter is relatively new and should not be heat soaking and the cable is easier to replace.
#20 | |||||
![]() Quote:
![]() I can drain every last drop of gas from my car, remove every fuel line, cut my spark plug wires, remove the fuel filter, fuel pump, and gas tank from my car... and the engine in my car will still "crank" - the starter will engage the engine and cause it to rotate, or "turn over" - fuel has nothing to do with an engine "cranking" but without fuel, the engine will not start or run Quote:
1) Engine will crank/turn over but not start on its own, but will start if jumped, or 2) Engine will not crank/turn over, turn key, solenoid clicks but nothing else happens other than the headlights dim (no other sounds, actions, no usual "whir, whir" of the engine rotating but not starting)
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
Bookmarks |
Love my Saturn | kwayne4588 | S-Series General | 2 | 04-10-2012 12:07 AM |
Love my saturn ac | CScheer | S-Series General | 10 | 07-25-2011 09:49 PM |
Why do I love my Saturn so much?! | SaturnManiac | S-Series General | 20 | 12-15-2006 01:27 PM |
saturn love! | 30pack | S-Series General | 3 | 06-29-2005 02:52 AM |
I just LOVE my Saturn Voo!!! | BlueDevil | Vue General | 3 | 07-30-2004 04:45 PM |
