Thread Tools | Display Modes |
#1 |
![]() Join Date: Feb 2009
oil leaks into the first cylinder where the spark plug meets the boot of the plug wire. pretty sure its not leaking into the cylinder but not 100%.. i think it is a valve gasket around the first cylinder.. wondering if anyone has attempted this project. if so would it be worth it just to take it to a shop, or is it simple enough to do it in my garage.
#2 | |
![]() Join Date: Aug 2009
![]() Quote:
Although I'm not sure people would recommend it or not I did use the replacement gasket and the high-temp silicone between the gasket and the metal. I did this 9 years ago, and have not had a single issue with it. Most important thing is correctly torquing the bolts. They are easy to break. If you have a dealership nearby you might want to buy a couple just to have on hand (but I am notorious for over-torquing stuff). Do a dry fit first so you get the hang of putting the valve cover down without unseating the gaskets. |
#3 |
alrighty, thanks for the response. in theory seems like an easy job.
#4 |
Also, I just thought of this, if you use the silicone, don't get any in with the valves... there is a risk it'll dry and potentially block one of the oil return channels...
#5 |
okay thanks for the tip.
#6 |
The torque value for the bolts is 89 INCH pounds
![]() Most important thing is clean all the surfaces using acetone or something that does not leave a residue. Torque evenly in steps (ie. 25 , 35, 45, 55, 65, 75, 89 INCH lbs -below is for the DOHC): INTAKE SIDE 9 - 5 - 6 -10 3 - 1 - 2 8 - 4 - 7 - 11 EXHAUST SIDE For the SOHC, JerryHughes did a very nice writeup. Search for a post under his name
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#7 |
Pretty easy job, 80% cleaning, 20% Removal and reinstallation.
Allot 2 -3 hrs if you haven't done it before and want to thoroughly clean/soak the plastic valve cover (simple green worked for me). The GM OEM gasket set fits well, although it comes in a cheesy baggie and makes you wonder. Costs ~$40 from GetSaturnParts.com. While waiting for it to arrive, you can always just let the oil drain from #1 into the cylinder occasionally to keep it from fouling by removing, cleaning, and replacing spark plug #1. |
#8 |
I got a felpro gasket from this ebay seller for about $31 shipped, but I just now realized the kit I got didn't have the grommets. Very fast shipping.
Oh well, I didn't realize it at the time I replaced it - I reused the grommets and they were fine. If you buy this, may want to have the seller make sure the grommets are in there if that worries you. Gasket fits well and works fine so far, was the cheapest i could find.
Bookmarks |
Tags |
oil, spark plug, valve cover gasket. |
1998 SL2 poor gas mileage (15 MPG!), oil on leftmost spark plug & P0341. | JayCal | S-Series General | 42 | 08-20-2012 10:48 PM |
oil in spark plug well | wednesday | S-Series General | 10 | 05-12-2009 10:40 PM |
White Ashy Deposits on Spark Plug Wire Boot | The Critic | S-Series Tech | 2 | 03-25-2009 08:44 AM |
97, SL2, 4 spd - Oil Accumulating Around Spark Plug(s) | dgrant09 | S-Series Tech | 3 | 02-18-2008 02:58 AM |
98 SL2 - Oil on exterior of spark plug - Help please. | jsraskin | S-Series General | 21 | 03-02-2005 10:14 PM |
