#1 |
![]() ![]() So I bought this compression tester from Harbor Freight. I'm comfortable in using this on a SOHC car with the exposed plugs. What do you do on a DOHC with limited access? Do you just screw it in through the top of the engine and hope you get it screwed down far enough??
7 Saturn Car Family with + 900,000 miles. 2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car. |
#2 |
![]() Join Date: May 2009
I plan on getting this guy, or maybe their other one with the other attachments on Monday.
Is the hose long enough so that you could prop it up between the hood and windshield and watch the gauge as you crank from the drivers seat? I thought I would try doing that so I could see the compression numbers with each crank to see how long it takes is build-up. The whole building up on fewer cranks the better thing. Don't you just screw it on until it stops though?
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014 I learn from my experiences. If I screw up, I'm sorry. |
#3 |
I borrowed a newish one from AutoZone with a deposit that looked something like that. A trick to keep from cross threading plugs is to attach rubber hose to the end of the plug to gently get the plug screwed in. With that in mind, I just straitened the hose on the compression tester and then threaded it in where the plug goes until it stopped turning. It seemed to work. It was sweet that my car came with an aftermarket remote starter. Made the testing much easier.
Truth alone triumphs, not untruth. |
#4 |
You do just screw it in, but wondering if you can get it twisted in enough. I guess I won't know until I try it,
#5 |
I've got a cheapo HF gauge like ^^^^^, and an beat-up Sun gauge that's older than half the members here. They both go into a DOHC just fine. I think most personal-use compression testers are designed about like this.
#6 |
Thanks madpogue. That's exactly what I was wondering. I have a DOHC Saturn I'm looking at buying this afternoon but it isn't running. I want to do a compression check, but being it's not my car don't want to get the tester stuck.
#7 |
They work fine. The o-ring makes the seal and you can get it tight enough to squirt the ring out. Gently hand tight works fine.
Bookmarks |
compression testing results | Amp67 | S-Series Tech | 3 | 05-27-2009 01:54 PM |
Cylinder 3 Misfire, Compression Testing Results | ChiliPepperSC2 | S-Series Tech | 88 | 01-01-2009 01:21 PM |
Engine Compression Testing | justinflo200 | S-Series Tech | 17 | 09-18-2007 01:13 PM |
Testing Compression in an S-Series | Saturn-Eh! | How-To Library | 20 | 10-13-2005 03:54 PM |
Compression and Leak Down testing. | Red97sc2 | S-Series Tech | 2 | 04-09-2004 02:37 AM |
