Old 01-09-2022, 11:29 AM   #1
SaturnGoTo
SaturnGoTo is on a distinguished road
Default 02 LW300 piece identification
Hello everyone,
I have a 2002 Saturn LW300 and I noticed a cracked piece. What is this piece and could it be causing any problems for my car?
https://imgur.com/a/qQKzBzC
SaturnGoTo is offline   Reply With Quote
Old 01-09-2022, 11:56 AM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: 02 LW300 piece identification
That is part of the crankcase breather system. L300s have an overly complicated pcv system. Must be the German Engineering, I have seen Mercedes with a similar system. That crack will let unmetered air into the system and should be replaced.
Old 01-09-2022, 12:05 PM   #3
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Yes that piece should be replaced as 02 LW300 stated
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 01-09-2022, 12:21 PM   #4
SaturnGoTo
Alright thank you!! I recently had some work done on the car and is now misfiring. They cracked that piece when reassembling it and I am bringing it back tomorrow to get that taken care of.
There is actually a backstory to it all. I had a cracked oil pan and had it replaced. Then oil got in the engine and spark plugs and was misfiring. They cleaned the oil, changed the spark plugs and seals to them. The engine ran better after that but then started misfiring after driving 50 miles. Looked under the hood and found that cracked piece that wasn't cracked before the spark plug work. Going to get that fixed and see what happens.
Old 01-09-2022, 06:10 PM   #5
Russet
If you can't get that from RockAuto or such a Salvage yard is your next best option.
Total Suspension Re-Build or Piece by Piece bushbr89 Vue General 2 04-01-2017 11:12 AM
1st Gen, 2nd Gen, 3rd Gen identification ruley73 S-Series Tech 12 12-13-2015 09:56 PM
LCA arm identification fetchitfido S-Series Tech 2 12-03-2010 08:14 AM
A/C R12/134 Identification drumr S-Series Tech 4 05-25-2005 01:43 AM
Identification Oggel8816 Miscellaneous Tech 2 10-15-2003 01:16 PM
