![]() Join Date: Apr 2021
Hi guys,
I replaced the clutch on my 05 Saturn Vue and i went as far as removing and replacing the flywheel. I got it all back together and now i have two misfires and a squealing noise coming from the engine. It is also running in limp mode. A month prior to the clutch i replaced all spark plugs and the coil pack. Im not sure if i was supposed to align the new flywheel in a specific position or not. Any help would be appreciated. |
I should probablly mention its the 2.2.
Other things worth mentioning, one of the upper transmission mount bolt holes is stripped. |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2016
2003 VUE 2.2L
Verify that you replaced all the ground connections back on the engine. T
Squealling or metal grinding?? When I replaced my clutch several years ago, I seem to recall there was something about the pressure plate that it could be installed wrong. Verify the clutch plate is installed correctly (not backwards). ALSO, verify the pressure plate is seated in the guide pins correctly, and not riding on top of the guide pins. John
2003 Vue - 2.2L with Manual Trans. (Swapped) Originally had 2.2L and Auto trans. |
Thanks for the response. I think my issues with having a starter wired improperly. I appreciate your time
#5 |
2003 VUE 2.2L
OK, Hopefully you have it running..
This is a link to some ground issues I had and some of the problems it caused. I ran a couple extra ground wires just to make sure. Never had any more problems after that.. http://www.saturnfans.com/forums/sho...d.php?t=216101
Tags |
clutch, crankshaft, flywheel, misfiring |
94 clutch replacement--must engine be removed to access clutch? | agingric | S-Series Tech | 3 | 11-11-2010 10:30 AM |
Flywheel/Clutch Knock after engine replacement | comanche | S-Series Tech | 4 | 07-12-2010 08:31 AM |
Engine rattle after clutch replacement | Lodogg2221 | S-Series Tech | 2 | 07-10-2010 05:37 PM |
Engine running strangely after clutch replacement | CNC worx | S-Series Tech | 6 | 05-03-2009 01:02 PM |
Clutch Replacement w/o engine removal? | tommy2tone | Miscellaneous Tech | 12 | 09-01-2005 10:46 AM |
