Old 05-04-2018, 10:01 PM   #1
timl865
timl865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to behold
Default 97 sc2 milky oil in valve cover only.. a lot of it.
My 97 sc2 with just 77k Miles started to run very rough and throw a misfire code. I popped the hood and found the no1 wire was loose at the plug. The was a ton of milky oil around it and it looks like maybe the spark plug grommet is bad. The oil in the pan and dipstick has no milk.. just clean oil... wtf?
timl865 is offline   Reply With Quote
Old 05-04-2018, 10:08 PM   #2
amazinghl
Default Re: 97 sc2 milky oil in valve cover only.. a lot of it.
PCV probably not working. Condensation is water.
00 Insight 72mpg
amazinghl is offline   Reply With Quote
What problems can be diagnosed / fixed under the valve cover / timing cover? Dalamar S-Series Tech 1 09-15-2011 09:42 AM
DOHC valve cover bolts (aluminum cover) VUEmaniac S-Series Tech 3 02-08-2011 11:54 AM
Valve cover (cam / camshaft cover) hard to remove JohnHupp S-Series Tech 4 08-07-2010 11:11 AM
Replacing composite/polymer valve cover with aluminum cover DOHC idaw8184 S-Series Tech 0 08-04-2008 01:31 PM
FS: Valve Cover Gasket for BLACK Plastic Cam Cover, S Series jmettee Classifieds 0 11-02-2003 11:48 PM
