![]() ![]() ![]() Join Date: Aug 2016
2004 VUE 3.5L
The corner repair shop inspected my AWD Vue and say the front tires won't pass. I am not happy as I'd replaced all four on 6/15/18 with Falken brand ones that claimed to be good for 65k miles! There have been 3-4 tire rotations performed at various times from then until now - assuming Pep Boys and such were being honest on the bills. I looked up Falken warrantee info and it seems I would have needed to document every rotation (and maybe more) for the warrantee to be valid. I may still contact them but I don't expect much satisfaction. Did I mention the car has only covered 22.8k miles since the installation? So I went on this site reading posts from others who were debating the "replace 2 tires or all 4" question and now my head hurts a little. I was leaning towards the idea that this is PART TIME system and - not living in bad snow country - I don't know if power has EVER been diverted to the real wheels in the last 22.8k miles. I looking for advice on my current idea: Buy 2 new Falkens place them on the front and keep the old ones in case my tires get slashed. And as far a future rotations go, always swap front to back. I don't really want to give Falken more business but, if there is anything to the arguments people make about there being differences in circumference of 235x60x17 tires from one mfr to another I'm not sure I have a choice. Thanks
2004 VUE 3.5L
Since I'm not getting any comments, I'll update a little. Based on much web surfing I am now leaning towards getting 2 new tires (the same Falkens I guess) and placing them on the rear. Many people feel that the 'You must buy 4 tires" argument is flawed. They point out that drivetrains have some built-in compensation for circumference variances and that no harm will result. I'd always favored putting the best tires on the front but everyone seems to say the rear will be better. I make sure the front is aligned first. And I'll measure the tread depth on the 2 better tires to see what's what. According to Falken's stats, the new tires will start with 10.5/32" depth. I Think the shop said my better ones are 8/32" but I'll check.
![]() Join Date: Oct 2019
It will still be your choice at the end of the day, usually, I buy 4 tires at the same time.
2004 VUE 3.5L
If all of my tires were 'bald', I'd buy 4 new ones too. I have since read other Saturn forums about how the 2004 awd system works and confirmed that the rear wheels are just along for the ride until the fronts lose traction. There is a clutch that then kicks in to engage the rear wheels. It is at that point where tires with different circumferences can cause problems. I believe Audi and Subaru systems (and probably others) work differently by sending some power to all four wheels all the time. Different story. I feel it is safe to just add 2 new ones as long as I place them both on the front or both on the rear.
#5 |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004
2 tires are fine. It's FWD most of the time.
2004 VUE 3.5L
Thanks! My only remaining issue is deciding where to put the new ones. Some posts I read preferred to place them on the rear as they would 'help prevent slipping & sliding' (or whatever). But maybe they were referring to full-time awd systems found in other makes. I've always felt that, when the fronts provide the power, steering and most of the braking - you'd want the best tires to be there. Worst case - a blowout - better to have that happen in the rear than on the front. Front End Align is sched'd for Monday. Will replace tires then too probably.
#7 |
#8 |
2004 VUE 3.5L
I guess - that in 50 years of driving - I've never really had a "blowout". Maybe I should not have used that term. I've just had a whole lot of tires that slowly went flat after being punctured by something. I even found one tire flat when I returned to my parked car, changed it, and ran over something very near my driveway and watched a different tire go flat after I'd parked! Two flats in one day! For now, I will keep the better tires on the front. I feel that this makes sense. I think it would be easier to steer and brake with two inflated front tires and one flat rear rather than the other way around.
#9 |
I think the reasoning behind putting the new tires in the rear comes from the idea that average driver is better at dealing with the front end of the car loosing traction than the rear.
Your choice in the end. Once the car leaves the shop they can stop anyone from doing a swap when they get home.
2000 LS2 (Sold, Sigh) 2003 VUE 3.0 FWD 2002 MINI Cooper R50 1978 GMC PU 7.4L 2020 Subaru Impreza |
#10 | |
![]() Join Date: Apr 2021
#11 |
![]() ![]() ![]() ![]() Join Date: Feb 2009
2001 L-Series 3.0L Wagon
A few years back, they (my oil change & sometimes tire dealer) refused to put the bad ones on the back per their independent study, I would think you want the traction in the front.
Angry White Planet Ohth.... The REAL "Salt Life"! |
#12 | |
#13 |
![]() ![]() ![]() ![]() Join Date: Aug 2012
2005 ION-3 Sedan
Time to replace tires ? | mlandusk | Aura General | 8 | 09-19-2011 10:17 PM |
Looking to replace the tires on my ’03 Ion 3. | johnbono | Ion General | 4 | 06-21-2008 02:31 PM |
Anyone have to replace tires yet? | webxfx | Vue Red Line | 1 | 12-06-2005 12:56 AM |
Tires - When you Replace them... | D C | Vue General | 9 | 02-11-2004 05:33 PM |
When to replace tires... | skijay | General Saturn Discussion | 9 | 01-23-2004 08:10 PM |
