Old 04-05-2022, 07:26 PM   #1
JosephN79
JosephN79 is on a distinguished road
JosephN79's Avatar
2004 VUE Red Line
Default Running Wire Through Firewall
Where can I run a sub cable through the firewall on a 2004 3.5 Vue Redline? My son had someone put it in and they have it going through the door jam on the driver side. He had the issue of locks unlocking and some lights coming on after he ran the cable. We thought we remedied it about a month ago with two new front door sensors.
Now he says it did it again, the dome lights wonít go off and when you use the remote to lock it, the security light stays on on the dash.
Iím going to try to run the cable through the firewall to eliminate it causing the trouble with the door. Then I can better isolate whatís happening.
Thanks in advance
JosephN79 is offline   Reply With Quote
Old 04-06-2022, 10:08 PM   #2
JosephN79
JosephN79's Avatar
2004 VUE Red Line
Default Re: Running Wire Through Firewall
I found a grommet inside the driver side fender and drilled a hole through the plastic above the scanner plug in, fyi.
primary wire for amp/thru firewall Q/A peeweenapalm L-Series Tech 3 03-23-2018 07:48 PM
Wire Through Firewall Bucky L-Series Tech 0 03-13-2012 08:09 PM
Where should I route my amp wire through the firewall Jchulski19 Vue Tech 0 03-17-2011 03:56 AM
Firewall opening for power wire DocFuture S-Series Tech 8 10-01-2003 07:04 PM
Wire through firewall? daniel124 S-Series Tech 3 09-23-2003 08:51 PM
