Old 02-25-2020, 12:58 AM   #1
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Default Trunk Reflector Light Bar
I've seen a few posts here and on Facebook of people wanting to turn the trunk reflector into a working light. Usually either for a vehicle width brake light or to just have additional lighting. I thought that having a light bar across the trunk under the reflector would look kinda cool so I wanted to see if I could make something work.
I used a red led light strip as well as a dimmer to get it as close to the brightness of the parking lights as possible. I think it came out pretty well and for the last few weeks I haven't had any problems with it. I did originally want it to come on at one brightness with the parking lights, and at full brightness with the brake lights, but I couldn't figure out how to make that work. I either wasn't wiring it right or it just can't be done with a 2 wire led strip so I currently have it wired to only come on with the parking lights.
I'll have a write up below if you want to know what I did to make it work.
List of Parts Used
Red LED Light Strip
White LED Strips
LED Dimmer
16 Gauge Connectors
Translucent Acrylic Sheet
16 Gauge Wiring
T-Tap connectors
Crimp connectors
Heat Shrink
Really Sticky Tape
I wanted to have an led strip run along the top of the trunk reflector, but I knew the current license plate lamps wouldn't work. They cover up to much of the reflector I'm trying to shine light through so I tried making some custom ones. I bought some translucent acrylic off Amazon and epoxied it into a little box with a small LED strip inside. I figured the best way to mount it back onto the car would be like how it was from the factory, so I epoxied the clips from the originals onto the new ones. Once it all dried for 24 hours it felt really solid. I'm not too worried about them falling apart.
With the new license plate lamps done, The light strip that will be going behind the trunk reflector can go in. The trunk reflector first has to come off the car and to get it off the car it is easiest to remove the whole trunk panel. It is held in by two big torx bolts on the center as well as 4 smaller torx screws in the each corner.
Pic of smaller torx missing
The whole panel then lifts up from the bottom a few inches, and slides up. Richpin has a good video on this if you need help.
If you look at the panel from the back, you'll see a bunch of tabs across the center holding the trunk reflector on. The tabs on the trunk reflector need to be carefully bent over these tabs for it to come off. I luckily didn't have anything break but this is over 20 year old plastic, and it was cold out, so I was pretty worried something would snap on me.
Now that the reflector is off the light strip can be stuck under it. I put down some 3M adhesive to mark where the strip would go, then put the strip over it. The light strip does come with adhesive on it, but I wanted to be safe with the better tape. The reflector just pops back over the tabs once the strip in on.
1/2
97 SL2, auto, 123K miles
Old 02-25-2020, 12:59 AM   #2
Zeebins
Zeebins's Avatar
Default Re: Trunk Reflector Light Bar
2/2
With the reflector off you can really see why I needed the thinner license plate lamps. The OE ones cover up the whole reflector but my thinner ones leave enough room above for the new light strip.
Before getting the trunk panel back on I wanted to do most of the wiring I had to do. I bought some water proof connectors to replace the license plate bulb sockets and for light strip under the reflector. I could just wire everything directly, but this will make getting it off a lot easier in the future if needed. There is a factory grommet that the wires for the light strip can run through.
I fed the wires for the light strip next to the factory wire loom to the drivers side corner of the car . Behind the carpet trim there are some wires that go to the tail lamp. I'm not sure if they are supposed to be partially exposed like this, but mine where, making it easy to tap into. The brown wire is the parking lights, the blue wire is the brake lights, and the black wire is ground. You can tap wither the blue or brown wire depending on how you want the light strip to function. I added a dimmer so they wouldn't be any brighter than the parking lights since I wanted it to act as a light bar.
With that done the only thing left is testing and putting it all back together.
Thank you for coming to my Ted talk
Zach
https://imgur.com/a/lFWvWF0
Old 02-25-2020, 10:12 AM   #3
trottida
trottida's Avatar
That looks great!
Regarding the 2 levels of brightness that you would have liked; perhaps adding second LED strip connected to the brake light circuit. One strip on for parking lights and 2 strips on for braking. You wouldn't need to dim the brake light LED's.
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 02-25-2020, 12:25 PM   #4
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
Amazing work! I love seeing all the detail you put into this!
http://www.youtube.com/velocitylabs
ErikTande is offline   Reply With Quote
Old 02-25-2020, 10:23 PM   #5
98_Gold_Uranus
98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough
98_Gold_Uranus's Avatar
Very cool! This looks like something I would definitely do lol. Turned out amazing, great job!
98 SL2, 70k miles, kept in the family since new!
Her name is Uranus :)
98_Gold_Uranus is offline   Reply With Quote
Old 02-27-2020, 11:59 AM   #6
Waiex191
Waiex191's Avatar
Nice work!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 03-13-2020, 11:55 PM   #7
Zeebins
Zeebins's Avatar
Light bar 2.0 is now up and running! This time I used a different style light strip and added brake light functionality. I think it looks a lot nicer than the dot pattern it was before. Thanks to jpsuli for showing me that smooth looking light strips do actually exist. I probably would have used it the first time if I knew they had existed.
Light strip used,
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 03-14-2020, 12:19 AM   #8
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
Beautiful Safety Design! I'm impressed with your ingenuity!
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Singer Serger 1985 - 14U64A & 14U34B
Old 03-21-2020, 06:25 PM   #9
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SW2
That looks sweet! I always thought about illuminating the "Twin Cam" on the gen 1 trunk lids.
1994 Sl2 5spd First Car, Stock: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd: Retired Daily, Not Stock: 192,000
1998 Sl2 5spd: Family Car, Stock :135,000
1995 SW2 4spd: Daily, Stock: 91,000
Old 03-23-2020, 04:12 PM   #10
trottida
trottida's Avatar
I like it! Great work!
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 04-08-2020, 05:18 PM   #11
That looks fantastic! Nice work.
I added that light strip to my Amazon list in case I get tempted to do stuff later
Old 04-08-2020, 10:39 PM   #12
Charlie
Administrator
Charlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant future
Charlie's Avatar
2008 Outlook XR
2005 VUE Red Line
Thumbs Up Re: Trunk Reflector Light Bar
Bravo! Great job, thanks for sharing!! I always thought it would be neat to do something like this with the SL2.
Charlie
2008 Saturn Outlook XR
2005 VUE Red Line
2002 L300 (sold)
Charlie is offline   Reply With Quote
Old 08-18-2020, 06:07 AM   #13
codyas
codyas is on a distinguished road
If youve got that dialed back dimmer for running lights.
May i introduce the regular old diode. I would assume a larger 2 or 3 amp diode would work..
Running light wiring. Dimmer than diode to LED strip.. Brake light. No dimmer than diode connect the diodes. Into the LED strip. Common grounds.
That way they will be brighter with brake lights. And light with brake with or without running lights. 2 diodes. Prevents backfeed through other lighting.
codyas is offline   Reply With Quote
Old 08-22-2020, 07:28 AM   #14
dummo
dummo's Avatar
1997 SW2
Really nice! Next logical thing to do is to develop this as a kit and sell it.
1994 SL1 new traded
1992 SL2 new traded for above
Old 08-22-2020, 10:29 PM   #15
Zeebins
Zeebins's Avatar
A kit would be cool but some changes would defiantly be needed to make it kit worthy. The brake lights are currently way to dim to be useful during the day. I’m also not really a fan of the style of strip I used the second time around. It looked better being one continuous line but it’s basically just the first light strip with a red rubber defuser over it so it’s no where near as bright. It doesn’t even defuse it forward, it defuses down making it even dimmer than it could potentially be. Electroluminescent tape will probably be the best way to go but I haven’t really felt like taking it apart again to try something new. I do want to try clear coating the reflector at some point though so maybe when I do that I’ll also order some new lights. The reflector is also different between gens and coupes and sedans so I doubt one kit could be made to work with all of them.
I still absolutely love the light bar though. By far my favorite “just for fun” project so far
Old 07-15-2021, 10:25 PM   #16
El_bell
El_bell is on a distinguished road
El_bell's Avatar
Took a little over a year, but the light bar has quit working a few weeks ago. Brake light portion still works though. Probably just a wiring issue, but all of the wiring leading into the truck lid are still intact. Haven’t really been worried about fixing it since the light strip I used was kinda crappy anyway. Also don’t want to risk breaking any clips holding the reflector on in this extreme heat we’ve had lately. Need to find something better.
Now is also probably a good time to mention that I abandoned my Zeebins account for reasons I’d rather not get into here…(although you could probably figure out why if you’re clever lol)
~Ellie
El_bell is offline   Reply With Quote
'94 Trunk Reflector TVETTER S-Series Mods 3 01-30-2014 06:04 PM
trunk reflector quiksc2 S-Series Mods 23 08-21-2007 09:39 PM
Trunk Reflector '94 SL2 AFIndependant2k S-Series Mods 13 05-14-2007 11:10 AM
sl2 trunk lid reflector removal swoker183 S-Series Tech 3 10-22-2002 02:54 PM
trunk lid reflector swoker183 S-Series Mods 14 09-06-2002 01:08 PM
