Old 12-02-2018, 04:53 PM   #1
cpufreak101
cpufreak101 is on a distinguished road
Default adding Air Conditioning to a model without it?
so I got a complete steal of a deal on an '06 ion, it was one owner, garage kept, had full service history, etc. however, part of the reason for it being so cheap was that it was a complete base model, it doesn't even have air conditioning (yes, under the hood there's no compressor or anything) so I was wondering if anyone had any experience in adding A/C to one?
cpufreak101 is offline   Reply With Quote
Old 12-02-2018, 09:10 PM   #2
ruley73
ruley73's Avatar
Default Re: adding Air Conditioning to a model without it?
I'm responding only because I don't think anyone on here has any experience doing this. I have not done this myself, but I can tell you that there is A LOT involved in doing so. You will need to install:
Compressor
Longer serpentine belt
Evaporator
Condenser
Thermal expansion valve
Climate control unit for A/C equipped car
Suction & discharge hoses
Hi/Low refrigerant pressure switches
And after all that, you will need to have the BCM and ECM recalibrated. I'm not trying to discourage you from doing so, but I want you to understand everything you will need to make it happen.
I didn't even mention the biggest obstacle yet, which is installing all the necessary wiring. Your car may already have the wiring provisions installed for the A/C components. If none of the wiring is there you'll have a lot more work to do.
2007 Chevy Equinox LT 205K miles
2018 Chrysler Pacifica Touring L 74K miles
ruley73 is online now   Reply With Quote
Old 12-02-2018, 09:22 PM   #3
cpufreak101
Compressor
Evaporator
Condenser
thanks for the reply, I was fearing computer stuff would be involved. at this point might try to put in a standalone kit (like the ones they make for vintage cars) as i know that'd at least work then.
Old 07-22-2019, 10:07 AM   #4
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
2008 VUE 2.4L
Computer work might not be a real issue, but just might be $$$.
To reprogram a computer for my 2.4L 2007 Ion, the tech charged me $100. When they reflash it, they just right over everything there.
I would expect that it would be relatively simple to get the computer stuff done. Ask around at your local shops and see who they go to.
Peter
CURRENT:
08 Vue XE Black 2.4L
07 Ion 3 Savannah Green Metallic 2.4L
04 Ion 2 Berry Red 2.2
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
95 SL2 Lilac Metallic
94 SW2 White
hudypete1 is offline   Reply With Quote
Old 07-06-2021, 11:10 AM   #5
CarolClark
CarolClark is on a distinguished road
Do you need any hassles? I don't recommend doing it because it involves additional installation and some parts to buy. It's more expensive than calling an ac repair company to install a typical ac for your home or clean it. But installing a standalone kit would be an excellent option. I understand the need to install an ac into a vintage car, but if you don't intend to use it every day, you can leave it as it is.
CarolClark is offline   Reply With Quote
Old 07-07-2021, 07:46 AM   #6
goaliemo
goaliemo will become famous soon enoughgoaliemo will become famous soon enough
2003 ION-1 Sedan
2006 ION Red Line
My 10+ years dealing with ions, I have never came across one that didn't have a/c. I'd probably buy it. I don't use the a/c in my cars anyway. Haha
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
goaliemo is offline   Reply With Quote
air conditioning
Air Conditioning Help sean882 S-Series Tech 3 06-03-2012 02:23 AM
Air Conditioning yangyingenius L-Series Tech 3 07-28-2008 11:59 AM
Air Conditioning cam Vue General 17 07-23-2008 03:07 PM
adding air conditioning to a 98 SL dulce75 S-Series Tech 4 04-19-2002 08:21 AM
